1992 3ZVE M/T
Out of the blue one day..... truck won't start. With the key ON, I got no CEL (check engine light). Starter turns, strong, no ignition. Checked plug wires, coil, secondary, distributor, all resistance values within shop manual specs. Checked ECU, wiring, CEL bulb (to ground, illuminates). Fuel pump good, pressure at rail during start. Spark check bad- no spark. CEL will not throw a code, (not even steady blink) since light won't ever come on.
After a few days troubleshooting stuff, the CEL decided to illuminate with the key ON, and then bingo, truck started fine, ran fine. Checked for codes, got steady flash (no codes). Had no problems for a few weeks, and then....
Drove to grocery store, no trouble. Came back out, tried to start truck, no CEL with key ON. Cranked engine, turned over for 1-2 seconds, CEL illuminated during cranking, engine started, ran rough. CEL stayed lit. Engine ran as if not all cylinders were firing-- hesitated during acceleration, wouldn't produce much power, ran very rough. Drove the short distance home, marginally.
Currently, the truck will give the CEL before start normally with key ON about half the time I try to start it. When it does, it starts and runs fine, CEL goes out after start. The other half of the time, I get no CEL with key ON, but sometimes it comes on halfway through cranking and engine will start, but runs rough and CEL stays lit. I can't get the CEL to give any codes in any case- it either doesn't work, of gives steady no-trouble flash.
I have checked (per shop manual) and tried unplugging airflow sensor, throttle position sensor, cold start injector, and oxygen sensor. Nothing changes.
I'm guessing I have either an intermittently bad ECU or ignition module, or bad wiring (although I have checked all I can think of for open/short). There's no check for the ignition module. Has anyone experienced this before?
Other than a bad ECU, what can cause the CEL to NOT come on with key ON prior to start? Does the ECU "talk" to the ignition module prior to cranking? Can a "bad response" from the ignition module prior to start cause the CEL to stay off prior to start? Then, maybe during cranking, a few "good" responses come from the ignition module and the CEL comes on? Am I on the right track?
I'm trying to figure out what part to spend money on first, if it's not a wiring issue.
