1995 4Runner sputtering
T4R4CO
I'll try to be brief, but there is some background to this problem. The car wasn't really running that bad, maybe a little weaker than the normal weak 3.0 except for a couple of exhaust leaks. I pulled the engine to fix some leaks (pan, front and rear crank seals) and install a clutch and hydraulic cylinders. Because of the oil I replace the timing belt; I did turn the engine a couple of times to make sure the marks were lined up.
The issue now is that it is a little hard to start, cranks too much, but is harder to keep running when it is cold. It will only idle at about 4-500 rpm's unless you keep the throttle open and run it at about 1500 rpm's. After a few minutes, when it begins to warm up it will idle at 8-900 but there is a slight sputtering, it stumbles when you try to accelerate, which increases the more you drive it. I have backed out the idle adjustment on the throttle body a couple of turns to get it to idle. After driving a mile or two it will hardly pull a hill (20-30 mph in 1st and 2nd).
I have checked the fuel pressure (40 psi) and it holds pressure after it is shut off. I've checked to see that the vacuum lines are in the right place. Saturday, I change the spark plug wires. The plugs, cap and rotor only have about 30-40K miles in them.
My first question is (probably elementary), but it seems odd to me. Maybe it shouldn't. When I adjusted the timing the adjustment bolt is now at the very bottom of the slot of the distributor. Previously, it was in the middle. Is that enough that I should pull the distributor and reset it?
Any other suggestion from those who are more familiar with this particular engine are very welcome and appreciated.
go to the second gen section(classics) your posting in the 3rd gen section (96-02)
thadjay
