1996 3RZ 3rd Gen winter trip across Russia / Siberia
I bought this car specifically for a winter trip across Russia and got some help from members here, so wanted to share the outcome of my adventure.
In case you are not aware, a Hilux Surf is a Japanese-edition 4Runner. The 3rd Gen has never been sold in Europe under either name.
The plan:
To drive the conventional route across Russia (with a side-trip down to Vladivostok) in summer / autumn 2017 and arrive in Magadan in mid October. Then return in the middle of winter, using ice roads, frozen rivers and generally trying to avoid using the same route as taken on the outward trip.
The vehicle:
I wanted a strong Toyota 4x4 with a manual transmission and a straight 4, 16 valve, fuel injected petrol engine. This is not an easy set of criteria to fill, but in November 2015 I managed to buy a seriously rare 1996 Toyota Hilux Surf. It was in terrible condition, so a lot of weekends were spent on a total engine rebuild, total replacement of all suspension components, and various other bits. I needed the car to be in perfect condition. I put foil-backed foam insulation behind every internal panel, under the carpet and under the head-lining. I fitted a 2kW Eberspacher Airtronic cabin heater running from a separate internal battery and diesel tank. The engine was running on 0W20 synthetic oil with 2:1 antifreeze mixture. All transmission and axle oils fully synthetic. All external rubber components were replaced prior to leaving. The rear seats were removed and a space-frame luggage rack / sleeping platform bolted down so as to have a heated, insulated sleeping space. I was running Yokohama IceGuard studless snow tyres which were fantastic. Extra fuel capacity consisted of 5x 22 litre petrol cans.
The journey:
My first week in Magadan was spent doing final preparations such as blanking the radiator with insulation, insulating the engine and battery. I also had time to take the truck on it's first run of the year....
...out on the sea ice of the Sea of Okhotsk.
Then after a side trip to Kamchatka, I headed out onto the Kolyma Highway. Two week earlier the temperature was around -48º C but a cyclone came over and temperatures were barely above freezing when leaving Magadan. Just after Ust Nera however, I outran the cyclone and was into the winter wonderland I had been dreaming of seeing for so many years:
Kolyma Highway, between Ust Nera and Kyubeme
On the gorgeous road to Oymyakon...
...meet a friendly reindeer herd.
It took a week to reach Yakutsk, which was pretty cold at -38º C mid-day temperature. Nice city though.
Then the real adventure began: The Lena River Ice Road. This was the toughest drive I have ever done. From Ulakahn-An about an hour south-west of Yakutsk, the ice road starts. It's 1200 kilometres to Peleduy, and from memory maybe 800 of these are on the frozen river itself.
This is the best bit: it got way, way worse. At times the snow had covered the tracks. In other places there was a phenomenon known as naled in Russian, where a thin crust of ice forms on top of liquid water on the main ice body, which is very dangerous for trucks. In other places the ice had heaved up towards the bank and the ice road was steeply cambered and covered in snow; speed was the only way through!
On the last section, from Lensk to Peleduy, I teamed up with a local (who had one eye) as the conditions were getting bad (blizzards and deep snow on top of cambered ice).
With some relief I reached Peleduy; but now the problems would become logistical. The only road to Peleduy is privately owned, and requires a permit to travel on. I however tried my luck, and after a bit of talking with the bored security guards at the checkpoint, I got an escort through the Talakan oil base. Then it's 100 kilometres on an access road which joins the public Ust-Kut to Mirny zimnik (ice road). This presented a new danger; the trucks had created deep grooves in the frozen ground which were much wider than my axle width, meaning a lot of sliding. Fine when there's nobody around but hair-raising when overtaking.
After two days, I finally reach Ust-Kut and get onto the BAM road, which here is wide and easy. It's a spectacular drive across the pass to Severobaikalsk however:
Severobaikalsk is truly one of the nicest towns I have been to in Russia; not for the town itself but for the stunning location at the top of Lake Baikal, which is magnificent in winter (and summer!). There is a short asphalt road from Sevrobaikalsk to Baikalskoye, where I found some tracks heading south on the lake:
It was a bit early in the season to be out on the ice, but it was nice and thick. Only problem was that there was more snow than I would have liked, and some rather large cracks. I jumped over this one. The lake is 800 metres deep at this point!
After 223 kilometres I reached Ust-Barguzin on the east coast of the lake (a wonderful area to explore in summer / autumn). From here there is a newly surfaced asphalt road all the way to Ulan Ude, though as I was heading west I turned off early and drove over the Selenge River onto the Trans-Siberian Highway at Ilinka.
From Irkutsk I took the Trans-Siberian Highway further to Marinsk, then headed north to Tomsk, which I would say is the nicest city in Siberia, certainly in terms of architecture. I then drove along the Ob, stopping in the beautiful village of Prokop, from where one can drive on a short ice-road to Narym, where Stalin was briefly exiled.
Not far beyond Prokop, at Kargasok, the highway ends and it's onto another ice road; this one across the Vasyugan Swamp, the largest in Eurasia:
This ice road leads up to the Ob River pontoon crossing in Strezhevoy, from where I entered Khanty-Mansi Autonomous Region (KhMAO), Russia's main oil-producing region. After a rest day in Surgut I continued north into Yamalo-Nenets Autonomous Region (YNAO), passing through Novy Urengoy where by chance I met an alumnus from my university, who drove me up to the Arctic Circle and showed me some of the drilling and production operations, which are very impressive. I love these Russian 6x6 trucks (especially when I got stuck and had to be pulled out by one!):
West of Novy Urengoy is Nadym and beyond another zimnik, following the remains of the Trans-Polar Railway, Project 501, one of the most brutal forced-labour projects of Stalin's GULag system. The rails are largely left intact, and where the winds scours the snow away, you can see them in this Arctic wilderness:
More chilling are the numerous lagpunkti (camps) which have been abandoned since the mid-1950s. Here are the dreaded 'punishment isolators' which any reader of Solzhenitsyn or Shalamov will recognise:
The end of the ice road brings one to Salekhard, capital of YNAO, exactly on the Arctic Circle, with views across the Ob to the Polar Urals; the easternmost point of Europe (still as far east as Samarkand or Islamabad).
Here I had some local contacts who took me out on an ice road, then on a snowmobile to spend a night with some indigenous Khanty reindeer herders, in a chum (conical nomad tent), which was an unforgettable experience:
Returning to Salekhard, I was down with food poisoning for a couple of days, but this was a blessing in disguise as, on my final day, I was awed by a fantastic display of the aurora borealis, the northern lights:
Then, time for the final zimnik, up the Ob from Lyabitnangi to Priobye:
Here's the end of the zimnik in Priobye...
...from here it was a pretty dull drive of around 3500 kilometres to reach Moscow.
Conclusion:
Distance from Magadan to Moscow: 13,875 km
Lowest Temperature: -45º C
Lowest cold-start: -31º C
Number of breakdowns: 0
Number of minor issues: 0
This was the realisation of a dream, following a lot of planning and preparation. Russia in winter is a whole different experience!
In time, I will write this adventure up fully on my website (below). For now, there are more photos on my FB page: https://www.facebook.com/EurasiaOverland/
Or on Flickr: https://www.flickr.com/photos/eurasiaoverland/albums/72157695048577031
Cheers
EO
The Northern Lights are something I wish everyone could see in person. As awesome as that photo is being there and actually seeing them is so much better. The way they shift and turn color is hard to explain to people that haven't witnessed them. It's truly one of the most awe inspiring events in nature.
The adventure you posted here is pretty amazing. Nice choice on the vehicle platform. In hindsight, would you have prepared the rig any differently?
Judging by the locals you visited I'm going to guess your fairly fluent in Russian?
Thanks for the reply :)
This was the first time I have seen the aurora, but I understand I had a pretty good view of them; they were moving fast at times, creating whirlpools in the sky, arcing and focussing above me. I saw shimmering curtains of green with yellow and red flashes and highlights. I was literally dumbstruck.
I absolutely agree that everyone should see them if they can. No photo can do justice to having these extraterrestrial lights dance above their heads on a cold, dark night. Just magic.
As for the car, I would not really have done anything differently. I would have left the snow chains at home, brought a shovel and made sure I had a decent tow-rope (mine broke immediately).
Getting home, I noticed the front upper ball joints were quite severely worn (new before the trip, genuine Toyota). The gaiters had split. So I think I would perhaps have re-packed them with low temperature grease (my theory is that the grease froze rock solid) and insulated the gaiters somehow.
I have basic, usable Russian but I'm far off being fluent.
EO
Wow thats quite the trip! Thank you so much for sharing, it was so fun and inspiring to read through. Your photos are great too!
What a great trip, and for you to do this alone, well i have to take my hat off to you on that one. Beautiful frozen wonderland, thanks for sharing.
That is one amazing trip & will show the guys here that the 3rz has enough power & reliabilty to get through anything when backed by a manual trans.
Great story, and well-told. Thanks so much for sharing.
That said, I think you're nuts. I'll stick to jungles, remote beaches, and hidden waterfalls. All that cold and white stuff scares me.
Thanks! I choose my trucks for reliability and ease of maintenance; very important if you're in very remote places and / or if (like me recently) you have very little free time in your itinerary for fixing stuff. Although the 5VZ seems like a great engine (we also don't get it here :( ), just based on access and number of moving parts, I see the V engine as more of a disadvantage than a bonus :) And I think the 3RZ is great! In Europe we're not very keen on petrol (gasoline) engines trucks, but I think the economy of the 3RZ is about the same as the wheezy 8 valve 3 litre diesels we commonly have here.
As for manual transmissions, I just can't live with automatics!
Planning plenty more adventures in mine :)
The plan:
The vehicle:
The journey:
"Jumped" the split in ice! Braver man than I am! Awesome trip
Hey fellow UKer. I grew up in rural Dumfriesshire. This is fantastic stuff, and I was checking out the trucks page on your site and it's really impressive how thorough you are with the builds. Molten zinc rustproofing! Are there more pics/details of the builds and how you set up storage, what kind of gear you took, emergency gear, etc?
Jhunt
