1996 4x4 Auto - shifting from 2 to L while moving?
Hi all,
Wondered if I could shift from 2 to L while moving? It makes a bit of extra noise when I shift from 2 to L, so wasn't sure.
The reason I ask is because it makes descending steep hills easier, without killing the brakes sometimes.
I know I can safely turn off the O/D, then drop from D to 2 while moving... as I've done it countless times.
But on really steep hills, I'd like to be able to then drop from 2 to L.
This is while in 2WD of course, but I was surprised when I was in Sequoia National Park this weekend and shifting from 2 to L while cruising down a hill made so much extra noise. It almost reminded me of when I put my manual-transmission Miata into 1st lol.
Yes, you absolutely can but you would want to make that shift at a very slow speed. Supposedly the auto trans won't shift into the low gear if the rpms are too high but why count on that. Slow down to a really slow speed, shift into Low and crawl down the steep grade saving your brakes from overheating.
Hi all,
L is 1st. Just 1st in an auto.
seltzernator
