I'm trying to get access to the power antenna motor and was wondering if anyone knows how to remove the front fender? I know you can go up through the wheel well for motor access. I have done that on two separate occasions to pull the motor out in order to remove a piece of broken antenna mast inside the motor prior to installing a new mast. This is different though. The bracket which the motor bolts to has detached itself from the inner fender panel. I think it was tack welded and the weld simply failed. Nevertheless, I can't figure out how to re-secure it without removing the fender. There simply isn't enough room to go up through the wheel well or through the gap at the door post. Perhaps removing the fender flare alone might work, rather than the entire fender? I'd like to do that anyway to repaint.
