1998 3rd Gen 209,700mi 4WD Elocker SoCal $7,500
Bearded Cabbage
TOYOTA 4Runner 4X4 4WD V6 Auto ELocker Limited - cars & trucks - by owner - vehicle automotive sale
I purchased this car in 2012 and I have been the only one to drive it since then. I found T4R early on and did a lot of the suggested modifications. Added a trans cooler, deck plate mod, ISR mod, and e locker mod (so it works in 2wd). This car has never let me down and I would drive it across the country tomorrow with no worries if I needed to.
Has a little paint bubble on rear hatch next to wiper
The seats don’t have any rips, even the driver seat. Yes it has a few scratches but its been driven up and down California and yes, even taken off road (Gasp).
All the recommended maintenance has been done by either preferred auto centere in thousand oaks ca or Toyota pro in concord ca. I have receipts for everything. All service records, oil changes from the day I bought it.
I have a sliding drawer storage shelf in the back, your choice if you want it or not...
Please ask me questions and ill respond in this thread and let me know if you want more pictures. I have this car in my driveway and im not driving it. Come look at it if you’re local.
Located in Ventura County CA. 209,700 mi $7,500
1998 toyota 4Runner 206,000 miles
4WD Auto V6 Limited
Electronic E Locker rear axle
Leather power seats
Power windows
Power locks
Rear heater
Electronic autoshift 4wd
Tundra larger front brake upgrade with Toyota pads and rotors
RadFlo Coilover 2.0” front springs/shocks
Sonoran Steel 2.1 suspension lift (Around 3 inch lift over stock)
FJ 80 OME 861 rear coils
Tokiko FJ 80 rear shocks
Sonoran Steel heavy duty rear lower control arms
SPC adjustable front upper control arms
Alpine radio Bluetooth with Focal 4 channel amp and Focal componant speakers
All Pro APX front bumper
LED Fog lights and driving lights
Weather Tech All season floor mats
99+ center console with cupholders
FJ80 16 inch aluminum wheels
265/75r16 tires Yokohama Geolander ATS with average tread left. Tires have about 65,000 miles on them. Always rotated 5,000 mi at Tire Man in Thousand oaks CA
U Haul Tow hitch
Water pump replaced at 200,000 miles
Timing belt replaced at 200,000 miles
Front wheel bearings replaced at 170,000
Rear wheel bearings and seals replaced at 170,000
Steering rack and pinion guide
Radiator replaced with OEM Denso at 170,000 miles
External transmission cooler and trans temp gauge
Valve cover gaskets replaced at 125,000 mi
Spark plugs replaced at 200,000 mi
Injectors rebuilt and replaced with factory Toyota injectors from WitchHunter Performance
LED reverse bulbs
AFE air filter (washable and reusable high flow)
USB outlet ports for rear seat passengers
Oil changes done religiously at 3,000 mi with semi synthetic and always Toyota filters.
1998 208,000 odo $7,500
https://lh3.googleusercontent.com/O...yiG9_9j0cQ1S_qM6lsFTKSRlOunldF_s9ZA=w600-h400
https://lh3.googleusercontent.com/Q...hran3bzGajC3ajXQp-Ip9OrQNiYByX0WK3w=w600-h400
https://lh3.googleusercontent.com/Y...HsKKp0rXCUX_BhvMqNUd2GB-xgFiLyGWi3Q=w600-h400
https://lh3.googleusercontent.com/m...bEJRkWcyfroVv8l9sM0-_eM0wXfz74nsy3A=w600-h400
https://lh3.googleusercontent.com/x...YPJjpJdEAn1tD7H6mkBMu8Kch2OHM88zmSw=w600-h400
https://lh3.googleusercontent.com/E...xKbFZcMYYmx_Xmwpd3Ro0d6FxCWBUlDQR0g=w600-h400
https://lh3.googleusercontent.com/z...VTHLAQFmv8NgwrXRA8aCdPC-iTbLGLV9gOA=w600-h400
https://lh3.googleusercontent.com/l...LT4w5-nK_XTRmEB82xqB6hxQAEV3clG9W8w=w600-h400
https://lh3.googleusercontent.com/b...-3RF8d6jesag-wpY3IBv_EVm2HglVYZJp3w=w600-h400
https://lh3.googleusercontent.com/J...mj8uJFVzswSkmZyZ6tw4mdELA83ihlHvRmQ=w600-h400
https://lh3.googleusercontent.com/I...mAOP-9X1iNWmtZMWHkYmwdaZNl1ZxZTuYJA=w600-h400
https://lh3.googleusercontent.com/N..._rbF9vj5LM7whcZyytabdQfHrPPNo6k8RhQ=w600-h400
https://lh3.googleusercontent.com/7...VWP9ez4TxQCE634w3YfahxjmSRThNYdqtpg=w600-h400
https://lh3.googleusercontent.com/t...lRIqg2Ktohaoha-OHbDiJuWZPmHhMXe4tYQ=w600-h400
https://lh3.googleusercontent.com/X...7FzgeE3UxKW4eORvLr1TJNRFH-NT46x-DsQ=w600-h400
https://lh3.googleusercontent.com/I...ikAzoi8w-dg59f2Ugbq4v0QEhhmtmBAlVDQ=w600-h400
https://lh3.googleusercontent.com/R...ZdsY3zuHa9lUD160kviSRpvxz8gdGA-6r5w=w600-h400
https://lh3.googleusercontent.com/z...Yrby8wTatNO9WpbRP9YU29W7FsPkIQpYoJw=w600-h400
https://lh3.googleusercontent.com/R...dLIURtZuinoDHo8s1LFdlqQMe525XOvKFIQ=w600-h400
https://lh3.googleusercontent.com/t...S7k6RCrxgm9BfPpfKw7sWcIoPeqMMopvhHQ=w600-h400
https://lh3.googleusercontent.com/m...zPT_klxlhR_A32IVQUcvGU7O13C5KrQotwQ=w600-h400
https://lh3.googleusercontent.com/V...Np725pWTAnDy3SVqDpiod9AnsrX7-dLY9Zg=w600-h400
https://lh3.googleusercontent.com/5...xw_fGYhtlN-CEsjqD10wBLsyzRBIq3T7o2Q=w600-h400
https://lh3.googleusercontent.com/H...3eLU46hd2KVkJpUD5JwQ7Yf6JcK20fhVPEw=w600-h400
https://lh3.googleusercontent.com/o...CA8HYKQIgku2Tb2s5tBtWUKF3e0sYMMIU5g=w600-h400
https://lh3.googleusercontent.com/5...B17DDySEXQqtenyB5Jz3ty-nAVPCFWy85Lg=w600-h400
https://lh3.googleusercontent.com/A...BIkti9D7telNvZvw-FjUsXwT6cZneTw4zog=w600-h400
Philthyphilthy
