FS 2000 Limited 4wd w/E-locker $5k Chambersburg, PA
My New 2000 Limited 4x4 E-Locker
Totaled!
2000 Toyota 4Runner Limited
RECONSTRUCTED TITLE
305,000 Miles
Automatic transmission
4wd & Rear electronic locking differential
I've owned this vehicle for the past 8 years. In that time I've done the following work.
Timing Belt & Water Pump at 200k & 300k Miles
Changed transmission fluid, front differential fluid, rear differential fluid, transfer case fluid at 200k, 250k, and 300k miles
Installed Bilstein 5100 shocks all around with OME 880 springs up front and OME 890 springs in the rear
Cylinders heads and head gaskets replaced
Various tune-up items
Front brakes upgraded to 199mm (S13WE) Tundra brakes
Front ball joints replaced with OEM Toyota at 200k & 300k miles
Replaced vacuum lines with silicone lines
Replaced fuel filter
Replaced sway bar links
Replaced innner and outer tie rods
Replaced steering rack bushings
Replaced rear driveshaft U-joint
Rear axles seals replaced with new breather
Rebuilt and replaced entire A/C system
Underneath the frame is in good condition. I treated it with fluid film for several years.
Replaced jammed power antenna with fixed Tacoma antenna
Aftermarket Kenwood radio with Infinity Speakers
ScanGauge II mounted in upper center by mirror
Hood with scoop installed
Butyl and foam sound deadening installed on floor and sides
Includes Cargo Cover, I forgot to put it back in before I took pictures
One of the rear shock upper mounts had broken off so I welded on upper mount relocation brackets to the outside of the frame.
Driver's side seat belt just refurbished by SafetyRestore.com due to SRS light & code.
Currently has a set of Standard Michelin all season tires on it.
Includes a spare set of alloy rims with Nokian Hakkapeliitta R2 SUV Winter Tires
Window visors and WeatherTech floor mats
The bad
Reconstructed title due to sliding on ice at low speed into a pole several years ago. The impact was to the front passenger side headlight area. The radiator support was straightened back out by a shop and I replaced the hood, headlight, front bumper, grille, and passenger side fender. No airbags deployed.
Interior is in poor to fair condition. The center wood looking trim around the radio is cracked.
The driver's seat is in very poor condition due to age and use.
The paint is very worn on top.
The fuel gauge doesn't work and says it is low all the time. I just reset the tripometer when I fill up and start looking for fuel around 200-250 miles.
I can't view your photos without registering and signing in, that ain't going to happen!!!
I'm sure no one else will either.
That's weird, I can see his pics in both links, w/o signing in to Imgur.
I can see the photos from the first link which is on this forum from 2018, but not hopefully new photos at the Imgur site.
This is what I see at the Imgur site.
