I have searched and really haven't found an answer. When I am on the gas my steering is fine. At low idle it is difficult to steer. Any ideas before I tear the whole thing apart? I figure the pump is fine. There is no noise or leaking at all.
your not supposed to turn the wheel wheel the car is not moving.
Is the fluid filled correctly? (i.e. hot or cold line depending on engine temp)
Check the belt tension. Tou should only be able to turn the belt 90 degrees by hand...any more and it's too loose:
if the belt sits flat like this
__
you should only be able to move it this far by hand
this is too much, and the belt may be slipping
/ or __ (upside down)
your not supposed to turn the wheel while the car is not moving.
:wtf:
:lmao:
john's right...
__
Care to explain?
Thanks LINY!! Got it done and fixed!! Belt was loose and now it steers fine.
Puts a lot of stress on steering components and tires to be turned while not moving.
Congrats on the fix dude! :reddance:
So let me get this right...it's not recommended to turn the steering wheel while the vehicle is not in motion? WHAAATT?
I could understand the stress to the steering rack, and end links when the tire is jammed up against a rock or other immovable object, but come on guys, how the heck is it detrimental to the vehicle to turn the wheel when stopped?
EDIT: I just re-read the post...stress on TIRES TOO?!? Come the f'on guys; you're telling me turning the steering wheel when stopped subjects the tire to MORE stress than it sees when traveling down the road?
Am I just missing something here??
You are missing something. It's been printed in every vehicle owner's manual since the beginning of time.
...I am not saying you're doomed if you turn the wheel while stopped. I am saying it puts unnecessary stress on steering components and tires.
