1999 Manual Trans pops out of 1rst Gear
William Pyle
So, Manual Transmission= it pops out of first gear when I take off-super loud bang. It doesn't do it every time, just every once and a while. Any feedback would be great. It has 217 K on the engine. I do know that the T-fluids need changing as I had my mechanic look at it recently.
Thanks,
Will
Check your shifter seat, and your shifter cap. You'll have to remove the shifter to see those parts.
Welcome :hello: to the fourm.
^^^^^ what they said. There's a bushing under the shifter that wears out I believe. Should be super easy to get to from the inside of the truck. Remove console, boots and then shift levers. Send pics and ask questions if you need help.
Head to Toyota maybe to get an exploded diagram and OEM parts.
Good luck.
Mine was popping out of third and I changed out the seat and socket for the marlin crawler set. So far it feels much better and may have popped out once since then but I'm not sure if I was just cruising in neutral anyway. Mine still grinds in 2nd once it gets warmed up, redline mt-90 is on the way.
2001ATL
