1st Gen ('86) rear window
imike420
I know this has been talked about on a few other threads but I don't want to buy a new motor if there is something else that may be causing the problem. I have checked the center console switch, the relays are clicking as they should be and I have about 12.xx volts at the motor. There is nothing else if I'm getting voltage at the motor right?
I'm pretty sure I've got a spare motor that I know works, but it might be rusted to the mounts. PM me if you interested in it.
If you need a motor any Toyota power window motor will work, they are all the same. I found this out the hard way, I ordered one from Toyota and a freind told me so I went to the bone yard and got one for $5, saved about $110.00, got mine out of a Camry
Do you know if ANY toyota window motor will work or just cirtain years or models or just driver side or passenger side?
Tear the motor apart and see what's wrong with it! It's not that hard and usually it's just stuck!
imike420 said:
I was thinking about trying to fix the motor but I don't know anything about electric motors.
You can't be any worse off for trying. Just open it up and see if the shaft bushings are dry. Maybe just needs lubrication. If you can change out a motor you could do this too.
Just tear it out and rip it apart, if you have any problems just post here with pictures (if possible) and I'll try to do my best helping you through the progress of fixing! :)
Usually the motor's gear is rusted or broken.
And in some cases the wires or coals (isn't that the english word for this stuff, the square looking pieces that "touch" the rotor) are apart or just worn...
Coals, now thats an interesting term, but it works. I know what you mean. We call them brushes (because they brush against the commutator) and they are made of powdered and pressed carbon. Yeah I agree this isn't rocket science and I would much rather keep the original motor. Ulfr hows the fishing up there. Ever catch one of those "barn door" halibuts?
Thank you for all your help I will try disassembling the window motor in the morning. Do you know of any guides for removing the motor/regulator assembly and repairing the motor? Thanks again for the help! :clap:
It's called coals in iceland! (Has the same word for it, coals are carbon as well :D )
Fishing up where? Iceland? Well, my nephew is a fisherman, but he's mostly in making whales explode (I'm not really kidding that much with that one..)
And I'm not so much for fishing either. :P But maybe I'm just not getting some joke or something. Haha. Would be quite typical.
Not joking really, I like to go out in the party boats here and fish the ocean and have caught some large Caifornia halibut. But the skippers always say the big ones are way far north. I guess I'm not really sure where Iceland is and I sort of assumed that most people like to fish. Happy new year!
Any motor will work, I would stick as close to the same year as possible. Take your motor with you to a wrecking yard and compare them.
I took out the old window motor and took it apart I greased everything up and cleaned the metal blocks that contact the center rotating piece put it back together and all I got was a *pop* then nothing. I took it to a local parts yard to compare and got one out of a late '80's celica for only $18 and $4 for a 60 day warranty, works great now! Thanks to everyone for all the help! On a side note is lithium based multipurpose grese ok to use on the regulator where it slides in the tracks? Thank you all again! :D
