1st gen (grey) supercharger guru's needed
Trialrun
so I'm in need of some 1st gen supercharger gurus, I recently bought SCrunner12's 2nd gen SC, however I came across a new, yes brand new 1st gen grey SC from a local gentleman….kinda like finding a unicorn, so of course I had to buy it. My question to you all is what am I missing as he said he bought it for his son years ago, he never installed it but some of the parts were removed from the box and lost (i've noted the the hoses, static pulley, mounting plate for the pulley, relocation brackets for the wires/dipstick were missing and throttle cable bracket), what else? Also what are the billet items, not sure if they are part of the kit, but they were in the box…..on to the pics
here are some more photos that the seller originally sent me
The billet aluminum parts are the FMU that came with some or all of the grey sc's. As Trd/ gadget later figured out, you don't need it if you attach a vacuum line from the boost port off the sc to the fuel pressure regulator.... Also makes install much easier with out it. As for missing parts the dynamic tensioner is way better than the plate... And I think you noted all the other parts that aren't there... I'm sure some vacuum tubing at the auto parts store will be in order as well.
Right on, thanks for the insight and clarification
I'm glad the billet parts are not needed because my 1st gen SC did not come with those. As for the mounting plate for the pulley, you can order it from TRDparts.com also the bracket for the throttle cable too, along with other pulley parts. The two items come in different packages therefore you will need to buy them both, they are about 150 each.
I took a look at TRDparts supercharger section and didn't come across these, do you happen to know the part or package number?
Yeah that's my fault I'm sorry, it's at trdparts4u.com. Dealer out of Texas
You just fill in the make, model (pre 01) year for me 1999 and instead of catalog choose trd performance
Once on the new page go down to trd replacement parts
Then you should find everything.
thanks guys, i'm going to order the following to make it a complete kit. Now I just have to figure out which one to keep and which to sell.
PTR29-60020
PTR29-60032
PTR26-35042
I know the coating on the rotors from SCRunner12's kit is peeled off, would that really affect boost levels or performance?
Iac check valve as well if you haven't got that. A good thing to do prior to the install is to compare the 1st hen and second gen instructions... You kind of combine the two.
