redskinboy
New 07 4Runner with 2500 miles - when did all of you get the first oil change - I know, I can check the owners manuel but I trust your opinions far more!!
<<<< said:I did my first change at 1,000 miles; then second at 5,000 in which I switched to synthetic.
J.A. said:I am thinking of doing my first oil change at somewhere between 1000 and 1200 miles. Then every 3-4k thereafter.
keylay31 said:isnt a 5k OCI recommended by Toyo?
keylay31 said:Helps to clean out all the metal machining shavings that might be left in the engine and whatever else is a by product of the manufacturing process, as well as just helps the engine "break in"
Jeff Kleb said:
I changed it again at about 5000 miles (3200 miles later) with Mobil-1 synthetic, and have continued using it ever since. I still change it every 3,500 to 4,000 miles, even though I could probably go much, much longer. Again, peace of mind for me AND no issues with warranty coverage.
My lease on my 2005 4Runner expires in January and the person lucky enough to get it from me 'second-hand' will definitely get his/her money's worth from a car that was well-maintained and hardly broken in. Heck, I probably won't even have 36,000 on it unless I drive it a lot in the next few months. I only have 27,000 and some change on it now.
