2 in 1 Led Fog Lights/DRL on 2019
IslandJim
Member
So did a little searching and only found one thread thread mentions the oem 2 in 1 Fog light/DRL. They mention an aftermarket 2 in 1 fog/DRL and there was a nice instructional installation video by AUER the manufacturer.
Wanted to get this option on my 2019 ORP but was inpatient and just settled for a KDSS and cargo deck model.
My question is does the actual oem 2 in 1 fog/DRL use the DRL setting on the signal stalk on the steering wheel or does the fog/DRL use another button like is provided with the AUER aftermarket product.
Would like to get rid of the halogen/DRL highbeams and add the AUER 2 in 1 fog/DRL's.
Toyota 2 in 1 LED Upgrade Kit – Auer Automotive
YouTube
Think there was another thread that has the above links but cant find it.
Thanks for any info on how the oem 2 in ! fog/DRL works.
The stock 2-in-1 has a seperate button. The column switch just turns on the DRLs in the headlight.
My only complaint is the 2-in-1 dims significantly between fog and DRL setting. Goes to DRL when you select the side marker light setting and headlights on (2nd and 3rd selection).
Does anyone know a way to rewire to have fogs turn on regardless of headlight setting? I want to avoid replacing with aftermarket fog lights.
youngrk
