Wow...I'm honored that want to copy me
Thanks!
You are definitely lucky in that you already have 17" rims. You have a ton of tire options open to you w/o needing to buy new wheels. Once you have the shrockworks bumper though you will hate your departure angle. Be prepared to start saving up for a new rear bumper... (my next big planned purchase). The approach is WONDERFUL and you can practically drive up to anything!
I didn't have a scale and so I never actually weighed the thing. It does way probably about 100#. Then you add the winch line and steel cable and it can get up to 250-300. I don't think you will have any major issues adding that to your vehicle.
Ok now tires...I have a feeling you are mixing and matching some numbers. The number C or E has to do with a load range and the number of plies. The more plies the higher the load range of the tire. A 'C' tire has 6 plies and an 'E' tire has 10 plies. The more plies the less likely to puncture the tire. Keep an eye also for the number of sidewall plies. The TA KO's have 3ply sidewalls. The more plies the less likely of puncture by rocks on trails. The only downside is that commonly more plies=rougher ride when compared to an equivalent tire. You probably only care about this if you plan on spending 99% of your time on pavement.
The load range is tied to but not dependant on the letter you are speaking of. You need to find out the load range of your tire based on the sidewall. Keep in mind these load ratings are based on a fixed tire pressure. The less the pressure the lower the load rating. They don't typically give you enough data to generate such a curve but I haven't heard of anyone having major issues with airing down to 20-25# and having load rating issues.
The 'P' number means it is a passenger metric tire.
The tires I have on my vehicle are: LT265/65R18/E
http://www.bfgoodrichtires.com/specs/all-terrain-t-a-ko/44.html
See the table in the link for more info about that fixed size. I couldn't put the 285's on because the rims on the stock ltd 18" are 7.5" and you need an 8" or you won't necessarily be able to keep the bead, especially when aired down.
Ok here are a couple of links for you in regards to tire info.
Basic tire definitions to help clear up any confusion:
http://www.discounttire.com/dtcs/infoTireTerm.dos
Tire load rating tables:
http://www.discounttire.com/dtcs/infoLoadIndex.dos
Read your sidewalls
