2 questions--throttle postion sensor, and trans fluid change
naseeb
Hey guys!!!
I'm new to this forum, actually I've been reading posts for a few years finally decide to join.
I have three questions.
I own a 99 SR5 V6
A couple months back I was getting a CEL for the throttle position sensor( would come and go). I sprayed some WD-40 on the trottle thinking that lubing it may stop the CEL. It seems to have done so. Just in case it returns for good, what does the part look like, and where is it exactly located. I figured if I sprayed the mechanics without searching around for the sensor, it would be my first step to fix the problem......so far so good. For all I know, I probably was staring at the sensor when I was spraying the trottle.
2. How much fluid drains out of the tranny. I have 85K miles on
and purchased it with 42K( tranny service was done at that time)
Shifting is smooth, but I figured it's time to change it regardless.
I want to make sure my oil pan is large enough to contain the fluid.
3. WHERE CAN I GET A CD MANUAL . The one that I purchased of EBAY doesn't work!!!
Cheers!! :)
