You get what you pay for man. I used to be an autotech installer at best buy and and the knock off alarms alway have faulty brains and don't last long. It will be more of a headache than it's worth. They forget crank times, sometimes recieve 2 transmissions so it will start, most don't have anti-grind, and will try to start again, tearing up your starter. I have the viper, go with the quality units man, most have lifetime product warranty, and best buy has lifetime warranty on labor, so if something happens you're covered on both ends.
My .02
Agreed, I needed a new alarm and was on a budget... After looking for a while and pricing things out, I found that if I went with a $80 alarm that didn't include installation, it would cost the same as a viper alarm that included professional installation. Plus its Viper...You get what you pay for man. I used to be an autotech installer at best buy and and the knock off alarms alway have faulty brains and don't last long. It will be more of a headache than it's worth. They forget crank times, sometimes recieve 2 transmissions so it will start, most don't have anti-grind, and will try to start again, tearing up your starter. I have the viper, go with the quality units man, most have lifetime product warranty, and best buy has lifetime warranty on labor, so if something happens you're covered on both ends.
My .02
understandable, but also keep in mind all the things you can add to the alarm (most of which, unfortunetly, isnt highly spoken about) such as window mods (roll down all windows via remote) glass break sensor (detects when glass has been popped by a tool, which, usually doesnt provide enough shock to set off the shock sensor) and proximity sensors (in a sense, provides an adjustable "bubble" for lack of a better word, around the vehicle, great for convertibles. Also, alot of the cheap remote starts dont have the extra ACC to allow your vehicle to power things such as seat heaters, climate control, radio, dash illum, etc.
as I said before, they are by no means cheap, but, worth the money. Granted, if you can find a "homie hookup" on the alarm, or even the install, that helps. You didnt hear this from me, but I used to do them on the side for $100, and you can usually find the viper units online for around 250. Just keep in mind, if you have an installer do it on the side, if you ever have an issue, you HAVE to go see him specifically. Dont screw him by seeing someone else and when they ask to see your reciept for warranty you tell them he did it on the side. He hooked you up, dont back door him
Call this guy....Audio by TJ 480-733-7077
His name is TJ.
He has done all my Stereo and Alarm work. Never had a problem with any install....He'll back anything he does and has been around for a long time.
He was running some specials on alarms a little while back. Tell him Clayton sent ya and I'm sure he'll help ya out.
I have 2 Clifford alarms. One in the Taco and One in the 4R. They work great and the range is incredible.
viper changed both the antennas and remotes. They have the best range on the market now. Plus, the have the iPhone app that can start/lock/warn all by phone using sat. with unlimited range
