20" Wheels rubbing and Hwy vibration..?
YellowRaven
Good day all,
I have the 2016 Trail edition 4runner
just had Brand new wheels and tires installed
fuel maverick D538 20x9 wheels
yokohama geolander g105 tires size: 275 55 20
this is the size that is to be correct for the vehicle, but on full wheel turn the tires rub on the mud flaps ,
and on the hwy between 45-70mp/h I get a steering wheel side to side slight vibration that was not there prior to the new wheel install
has anyone else experienced anything similar when making the size jump to
20" wheels from the stock 17" ?
any info helps
kind regards
Good day all,
any info helps kind regards
Hi YellowRaven,
This may help you a great deal: https://www.google.com/url?q=http:/...ds-cse&usg=AFQjCNFnmIQXDz_g2m7mEun0JofORQrLpQ I'm running 275/55 R20 and no problems as well as other members here... the tires and rims will need to be balanced as well! 'Hope this helps'!
rig, cheers
Is the offset and backspacing on the rims the same as the limited wheels? If not and they stick out further, that could be why it's rubbing.
[MENTION=164651]YellowRaven[/MENTION] Also remember that no 2 trucks are alike.... what rubs for some, may not rub for others even with the exact same setup.
Another note is that those wheels are probably not hub centric. I will never run lug centric wheels on my 4Runner after vibes using lug centric wheels on my old Tacoma.
