ftatester01
Folks,
I have a very strange problem that just developed with my 2000 4Runner Limited.
The radio usually have two levels of back lighting, dimmer when the headlights switch is in the on position, and breighter when the headlight switch is in the off position.
Recently, something faulted and im not sure what. Now, the radio backlighting is dead when the headlights switch is in the on position, and its very faint when the headlight switch is in the off position.
The airconditioning/Heater panel works the same way as far as having two levels of back lighting. This still works fine and did not fault like the radio did. However, a little while ago, half of the LCD screen on that unit lost ist back lighting. That is however a different problem.
I guess i have two questions. Does this sound like one set of backlight or LED in the radio got burned out. If so, any info on its location, replacement, etc will be appreciated. Or is it a control issue, relay, fuse, etc? A wiring diagram may help answer this, but i dont have one.
The other question, is also regarding the LED backlighting in the AC control unit. Does anyone have info on the replacement too?
I wonder how easy it will be to get to those units and get them out to troubleshoot. I figured it will be nice to talk to someone that has been there before i start the project.
I appreciate any help I can get. My email is [email protected]
