2000 4Runner Supercharger question
mdm4953
I am considering buying a 2000 4Runner "Limited" edition from the original owner, but he claims it came with a "factory installed" TRD supercharger. I saw on this forum where some people were saying the TRD superchargers were not an option from the factory during that year model, so I'm confused.
Does anyone know if the 2000 "Limited" 4x4 models did indeed offer a "factory installed" TRD supercharger back then? If so, what are the pros / cons of having this option on one? Does it affect gas mileage much, is the maintenance or upkeep bad, and do you have to burn premium fuel?
There is a million answers to your questions. We will need to know what color the supercharger is, Gray or Black? Also how many miles on the truck? Any service records? There is more pros to having the SC than not IMHO and it does not affect MPG if you don't floor it every where you go.
It wasn't a 'factory' option, but it was a 'dealer' option. Meaning that they could order the 4runner and the supercharger from the dealer. Then the 4runner would show up to the dealer and they would install the supercharger before the customer first picks it up.
Its just a matter of terminology.
"Dealer-Installed" TRD Supercharger in 2000 4Runner Limited?
Thanks for the quick help...I think it is a grey supercharger. Makes sense what you are saying...the dealer must have installed it when he bought it back in 2000 then.
It has 135,000 miles, has all the maintenance records, and has recently had the timing belt and water pump changed (have proof of that too). Sounds like exactly what I want, but I'm just trying to get advice from all of you as to whether or not I should worry about it having a "dealer installed" supercharger from back in 2000 or not.
sounds like everything I read online says when you install one of those, you need to upgrade the fuel system and a few other things. If the "dealer" installed it for them when they bought it back in 2000 brand new, is it safe to say the dealer SHOULD have upgraded those other things too in order to do it correctly? Thank you - any advice or help would be greatly appreciated. I am thinking of buying this 4Runner tomorrow unless anyone talks me out of it.
Do you have to burn premium gas, or is regular unleaded OK? Do most "dealers" install them the right way meaning upgrade the other stuff that is needed?
Yeah you either need to upgrade the injectors or add a 7th injector. TRD made a 7th, but the buyer needed to have bought it also. It is possible to run without injection upgrades, but the engine won't get enough fuel at high rpms. You also need an upgraded fuel pump. I do not believe that TRD made one of those.
Mpg's are about the same if you are easy on the throttle. Yes you must burn premium fuel.
Yes .... premium fuel always. PERIOD I paid over $4.23 a gallon today.
IMO a proper set up for a TRD supercharger system should have at least some kind fuel management system and Air/Fuel Gauges so you can see whats going on.
If none of the above is available. I would do some additional test for the biggest and most damaging problems with TRD S/Chargers it is pinging.
Pinging is damaging and hard on the engine. I would test drive with a OBDII plugged in so you can see the air/fuel mixtures. I would begin by rolling to 2500 rpm then go wot then slow to 1500 rpm roll to 3000 then go wot. I would do this through 3500, 4000, 4500, 5000, 5500, 6000 roll to then wot for a couple of thousand rpm. All the while listening for pinging. If it's pinging you can assume that's been going on since new and the risk involved to the 135K mile engine. It may/may not throw codes Po171 or others which is another indicator that you have a leaning problem.
Once this is done and you know what you have, then you can decide if thats what you want to purchase.
Kowning what I know now......a MUST is have someway of monitoring the air/fuel at all times. You can do this with an Air/fuel gauge or ScanGauge.
Also a fuel management system. I have the URD 6injector kit with Fuel/Air calibrator which requires alot of tweeking which is good for fine tuning the engine. The cleanest and most effectively easy fuel management system is URD 7th injector. Lastly, a larger fuel pump is needed regardless.
As far as my experience with the TRD S/C . The preformance is there but remember its a 4000lb SUV and not a sport car. The NA 3.4L is very capable for most of what normal 4runner owners want to do with them. The S/C is cool but IMO not a must, I specificly looked for one because most of my toys are with either S/C and Turbo'd modded high performance vehicles.
The MPG are already a challenge with the 4Runner and the S/C will challenge that further. We get about 12 mpg and thats normal driving at 4500 feet mountion area. At other elevations of 1200 feet we may get 14 mpg city/highway combined.
Buying a S/C engine that has not been managed and maintained can be costly to repair or replace if needed. My son and I collectively have the tools, equipment and HIS knowledge to do most of the work needed to our vehicles which equates to substancial savings not afforded to most.
Having said that, these engines are very forgiving but not bulletproof. S/C put alot of pressure on the engine keep that in mind when having your truck evaluated and tested.
I commend you for researching this forum for information. Good luck with your purchase, assuming all works out with your purhcase. I can tell you these things S/C are fun and much faster than stock. WOT it hauls A$$...
Hope this helps........8sm
My Supercharger was installed before the original owner ever test drove it. My title from the Oregom DMV Shows "4Runner Supercharged."
I am not sure, but this may be a way to tell if it were installed new?
Also, if it's grey, and on a 2000, I do not believe that it was installed by the dealer.
IIRC the 2nd Gen (black) supercharger was released in 1999. My 1999, from the dealer, came with the black supercharger.
I get a consistent 17.8mpg City/Highway mix.
Do some reasearch Here
And I would recommend ordering anything you need (7th Injector Kit) Here Gadget's customer service and knowledge of the TRD Supercharger are unreal.
New mexico, eh? Where abouts?
To check for the 7th, look on the backside of the supercharger right by the throttle body and see if it has some wires and a fuel line feeding into a part on the back of the supercharger. Or just post a pic, Ill tell ya.
