2000 4runner v6 sr5 manual transmission chirping and squeaking PLEASE HELP!!!
grga
i have a chirping in gear and in nuetral with the clutch depressed, the chirping is relative to the rpms while driving and reving in nuetrel and it disappears with the cluth very slightly pressed (barely need to press it). i also have a loud squeaking in reverse after letting go of the gas when the truck is slowing down, the squeak sounds like a kreeking door being closed and opened rapidly the sound also dissappears after the clutch is pressed. this also happens in first gear but not as loud.
ive done some reading on a lotus elise forum and it seems i have pressure plate problems or a simple slave cylinder issue.
Can someone please help!! i dont want my tranny to crack on me if its the pressure plate!
Did you discover the issue?
Just wondering if you ever figured out this issue. My 4Runner is doing the exact same thing and I'm clueless as to what is causing it.
