Hi All
My 2001 SR5 4WD (80,000 miles) started showing the following symptoms: High pitched whining noise when in Drive (forward or reverse) (this sound does not occur in Park or Neutral). Also some clunking noise when Reverse is engaged from Park. Also note for about six months, truck would not move right after pressing the gas when Reverse was engaged (about a second delay before vehicle started moving).
Took it to the dealer who services the vehicle and the outcome: Internal transmission problem, recommend replacing with factory rebuilt transmission. Cost $4,000.
Was not really expecting to spend such serious $s so early on a Toyota. So still trying to absorb the news.
Questions/recommendations requested:
- Was my confidence on Toyota quality misplaced ? ;-)
- Anyone else seen similar symptoms and what was the outcome?
- the reason quoted to replace the transmission was fixing it would cost about the same and not assure as good results. Should fixing it be pursued?
- Any suggestions for a reliable independent shop in Metro Nothwest Boston?
- The truck is due other repairs (brakes - still original, timing belt, AC etc). So I am starting to wonder how much money to sink). Too bad I just missed the cash for clunkers program.....
Thanks in advance for your help !!
