2002 4Runner transmission whine noise
poundkey
O.K. I've done all sorts of searching on this and come up with two forum threads that describe my 4Runner's symptoms exactly: one guy was told that his transmission pump was going bad, so he traded his 4Runner in to get a different car; the other guy was told that his transmission needed to be replaced, so he replaced it (at high cost).
I'm hoping somebody else has had this happen and can tell me the resolution without letting a mechanic have his way with me!
The model: 2002 4Runner SR5 4WD, automatic transmission
Miles: 218,000
The symptoms: I'm hearing a whine when I put my transmission in Drive or Reverse. The whine sounds like gears -- kinda like when you hear someone backing up really fast. If my car is parked, there is no noise until I shift into Drive or Reverse. There is no noise in Park or Neutral. When I start driving, the whine increases in frequency with engine RPM, but the whine stops if I shift into Neutral or let my foot off the accelerator pedal. I notice it in first and second gears. It's too quiet of a noise to hear if I'm going fast enough to be in higher gears.
I've done some close listening, and the whine is definitely not coming from the engine compartment. I hear it most clearly under the car (where the transmission is!).
The whine seems to be more noticeable when the car has not been driven for several hours.
I've done a complete transmission fluid flush twice over the life of the vehicle, and the fluid has always looked and smelled good. I use Mobil 1 synthetic ATF. The current ATF level has been checked, and it's good.
Before I shell out a whole mess of dough to replace an entire transmission (since that's what the mechanics will likely want to do), has anyone experienced this before and resolved it by replacing a transmission pump? Is there even a transmission pump? My Hayne's manual doesn't mention a transmission pump anywhere.
Thanks for the help!!!
04 sr5 whining 120k miles
I bought the car about 5 years ago with 70k on it. It has been an great car but I cant figure out what is going on now...
In 2010, I was getting the whine of the alternator going bad so I took it in and had the alternator and battery replaced. It was fine up until this past Thursday morning. I'm pretty in tune with the sounds of our cars, so when I noticed the whine, I took it in to the shop that did the alternator. Luckily, the alternator was still under warranty, so the shop replaced it with a new alternator and replaced the tensioner pully. The WHINE STILL REMAINS! I've looked on this website, but I'm still not sure what may be wrong. I'm worried it could be the tranny, but in talking with people, they and I don't think so because the whine exists when the car is in park and neutral. I'm wondering it might be something with the differentials. At this point, I'm planning to take it back to the shop tomorrow morning. I'll let you know what I find out and hoping you'll do the same if you have any developments...
thanks, Mark
I bought the car about 5 years ago with 70k on it. It has been an great car but I cant figure out what is going on now...I HAVE 120 K MILES ON IT NOW....
thanks, Mark
transmission pump
I learn something new every day so I guess today is just another day. What is a transmission pump?
If you have symptoms of a tranny going bad there is really not much you can do besides give it a few flushes. These are closed systems, they simply work until they fail, period.
If you already flushed it twice then you may just have to accept that it is on its way out. It could last 5,000 miles or 20,000 who knows...
I don't see the point in replacing it early, just drive it until it dies. I have two vehicles so that is what I would do.
In the mean time start looking for wrecks with 100,000 miles on it from compatible vehicles.
:girl:
