Seeking a good wiring diagram - also does anyone know where the WHITE lead goes that connects to the battery cable (has a but securing to the battery terminal connector) and goes UNDER the fuse box. That is where my grounding drain is happening. Something fed by that white cable.
UPDATE: I narrowed the drain to the 15a fuse for DOME LIGHT. I removed all dome (LED) bulbs be that didn't fix. Something along that wiring is grounding out. Any thoughts where to look next?
more details:
I have a battery drain. I thought it was the battery itself, but doing a quick and easy test light test.... I found that when I disconnect the POS cable. Place a test light to act as a jumper between the freshly charged battery and the disconnected POS cable - the test light lights up. Meaning there is a grounding issue in my wiring ...somewhere.
I'll keep investigating, but wanted to post something here early for some help.
Cheers.
more details:
Cheers.
