2002 Original Alternator
I bought my 4Runner brand new in August of 2002, Sport Edition. It now has 285,000 miles and still looks great. I do all of my own maintenance and I keep thinking about my alternator. It’s original and shows no signs of weakness. Do I wait for it to fail or do I make a preemptive strike and replace it?
This thread took on a life of it's own! Just to let you know my alternator failed at 333K. That says a lot about OEM. Anyway, check out my post in my build when you do remove the alternator for either brushes or a new Denso. HEre's the link Rock Rat's Alternator Replacement.
A couple of key points for you:
  • Don't try and disconnect the connector until the alternator is out and on its side
  • There's a bushing that needs to be reset "flush". Use the socket method I used.
No kidding I say this because I saw someone on here grind his alternator to try and get it to fit. I'm not sure what the outcome was, but it was a matter of just setting the bushing flush.
Have fun!!
I'm jealous that you guys are getting 250k, 300k and 333k out of you original alternators. I would have been happy with 200k+.
My 3rd gen at 188k is on it's 3rd one. As a matter of fact it seems to fail so often that I now have a spare on the shelf for when it fails next.
And because of that experience I replaced my 5th gen's alternator at about 87k as a preventive measure. That's what lead me to this thread as I want to rebuild the old 5th gen alternator so it's ready to go when the currently installed on fails.
Something has to be wrong in the electrical system for the alternator to fail so often. Frayed wire, bad connection??
Have fun!!
Thank you very much for the info and advice. It’s much appreciated!
You replaced it with aftermarket?
I think you went with an aftermarket alternator with a lifetime warranty... This is a BIG no. Stay with the OEM and just replace the brush kit. If you have a lot of electrical accessories, then you may fry the diodes other than that, it will run forever!
