2002 toyota 4runner 2.5 rear spacers installation
jad4192
hello gang!
i have a 02 Toyota 4runner and i just bought a pair of 2.5 spacers for the rear so it will level with the front. My questions are: Will the rear be leveled with the front if i install them? Will the rear be a little higher than the front, if it is, will that be a problem? Or will everything work out fine either way?
Thanks Guys! Feedback much appreciated.
Depending on the current stance of your truck the 2.5" spacers can yield different results. Just do an initial measurements first on leveled ground. measure the distance from ground-fender both front and rear and determine the difference..add 2.5" on the rears measurements and that's how your truck will look like.
more than likely you'll have a higher back end or a rake but that is not a problem. having the rears a bit higher is better to compensate for sags especially when loading the cargo.
