E El Chino New member Mar 9, 2008 #1 The rear wiper on my 03 4 runner isn't working, neither is the water for the rear window. Is there a fuse involved that may need to be replaced? If so, where is it? Let me know if anyone has any idea how to fix this. Thanks!
SP Jon M3 New member Mar 10, 2008 #2 Make sure that your rear window is completely rolled up. If it's not rolled up then the wipers, washer fluid, nor the defroster will work.
T toto New member Mar 10, 2008 #3 That will probably do it. If the computer thinks the window is open by even the slightest amount, the stuff in the back won't work. If you disconnected the battery, then you need to re-initialize the computer for this and other things. See this thread if that's the case.
E El Chino New member Mar 11, 2008 #4 It Worked... Thanks! I did unplug the battery a couple weeks ago. So I just tried resetting the back window like you said, and it worked. Thanks for your help!:dancin:
K kjroadbiker New member Mar 14, 2015 #5 Thanks SP Jon M3 said: Make sure that your rear window is completely rolled up. If it's not rolled up then the wipers, washer fluid, nor the defroster will work. Click to expand... I know this is an old post but it worked for me.
