2003 Rear Bumper Cover Removal
Buckaroo93
I need to remove the stock 5K lb WC hitch and install my full frame mount WD hitch. Looks like I have to remove the bumper cover to have access to the top bolts. SURELY there is a way to remove the center piece instead of removing the ENTIRE 3 pc assembly. SURELY!
I remember removing mine a long long time ago, it's all bolt/clipped/screwed together and then installed on the vehicle (assuming my memory isn't faulty).
So you actually have to pop the cover off and the break it down into it's 3 pieces. The good news is that you can get the cover on and off pretty easily as an assembly, so I'd just pop it off and install your hitch. :)
MaximussK
