Coolant cross-over pipe leak
davidaw
Member
Hi Everyone.
I've searched and this does not seem like a common issue. But what I have found sounds like it may be tough fix.
08 v6
Any help is appreciated.
I recently got a sudden coolant leak from rear of engine onto the BH and Transmission.
Managed to get pics/vid and saw it coming from rear water bypass joint.
Almost impossible to get to directly. Manual says to pull the engine.
But some posts said to remove all the intake to get access or drop transmission.
I pulled the intake top and bottom and then pressurized the system. I could see the coolant coming out around the center pipe and not the 2 ports to the heads.
Pulled the water bypass to get to the O-Ring.
Ugg. It looks like the crossover pipe is corroded at that end and prob would not hold the )-Ring.
I'm hoping someone has seen this and can advise if I'm right.
Questions:
1. Am I correct that I now need to replace that crossover pipe as well?
2. Am I correct on how the O-Ring fits on the pipe?
3. How bad is it to replace the pipe? Manual says to pull one of the heads. But I saw at least one post where they managed to force it in somehow.
.First pic is where the leak is, O-Ring is in there.
I think its similar pipe/O-ring on other end
Pic 2 is end of that pipe- O-ring came off as I pulled but it looks like it falling apart and would not hold O-ring
Pic 3 is how I think the O-Ring fits before pushing the water bypass back on. But pretty sure it wont stay on with the missing metal on the pipe
2001ATL
