mac777daddy
Hello,
I am in the process of doing a front brake job on a 04 4runner SE v-6 model. I took the brake caliper off and didnt know you are not supposed to take the caliper apart until I had already done it. I called Toyota and they confirmed you are not supposed to take the caliper apart just take the caliper loose to change the pads. My question is had anyone taken a caliper apart before? Brake fluid went everywhere. I put the caliper back together and the leak stopped. Does anyone know how many rubber o rings are inside the caliper once they are split apart? I put one back in that is near the top of the caliper and lines up with where the brake line fits onto the caliper. Once I put the wheel back on I found another o ring on the ground. I didnt know if I missed an o ring or if there is just one o ring in that caliper??? Thanks Mac
