2004 4Runner V6 Transmission oil change
PTPT2002
Ok, i know this might have been mentioned a few times in this forum but i just want to get a straight answer.
I have 60,000 miles on my truck now and I don't do any towing. As a matter of fact, i only do mostly highway driving.
With that said, when SHOULD i change the transmission fluid in my truck? I know this comes with long life fluid but nowhere in the schedule maintenace book specify when it is supposed to be replaced. (well, it did say if i tow then i should replace the oil at 60k). The ATF dip stick says that i shouldn't change it under normal driving condition.
Fluid changes are cheap, transmissions are not... I would change it even not towing. You don't HAVE to but for $100-$150 why not? I can't imagine a transmission costing less than $2g. Should you keep your T4R until the 140k range why not have a vehicle you feel confident in? Just my 2cents
