Owners of 2004 4th generation 5 speed transmissions with the sealed transmissions (no dip stick) and the new "WS" world service transmission fluid. Toyota states that it does not need to be serviced because it is a "life time fluid"? This "WS" fluid can't be mixed with any other fluid and there is no substitute fluid on the market. I know that the only reason to change transmission fluid is to eliminate contaminates and to refresh old fluid that is damaged by heat. With this change the 2004 transmission is now a sealed unit that keeps contaminates out of the transmission and the new WS fluid being a life time fluid gets rid of the risk of getting contaminates into the transmission and Toyota must feel it is more heat resistant then previous fluids, since they recommend servicing it only if you tow. It seems like progress, Toyota eliminating the dip stick and upgrading the type of fluid with the 2004 V8 model. Dealers even recommend agains't changing the fluid on these units.
Have you serviced or do you plan on servicing your 2004 V8 5speed transmission?
