I've got an 2004 4Runner 4x4. Overheated. The radiator cracked, steam rolled out from under the head and then my son had it towed to Firestone. They tell me the head is warped, the gasket is leaking, failed block test, and cylinder 6 is dead.
Great, I think, not really. I have 223K miles on this vehicle. In the past two years I had it painted - clear coat disintegrated; I had the struts/springs/shocks done; I had all new rotors, and two new front calipers, and just put on new Coopers AT. All in all about $6K in the last 2+ years. Oh yeah, i had a tune up done about 2 months ago.
I'm being told the job will run about 18 hours, give or take, parts - cost will run nearly $2K-$2.5K. I'm thinking that's a lot but most everyone else is quoting the same. The shop says if I pay that kind of money for labor I should consider a donor/used engine. Those cost about $2500 or so. Toyota would do the engine replacement for $5500 and the engine comes from LQK.
So I'm thinking of doing the impossible or not. I'm thinking to open the engine up myself, pull the heads, and send them to a machine shop to be resurfaced and then put it all back together plus take out the old radiator, change out the old water pump...you know. I'm sure I'm missing something in this thought process due to my lack of experience but I'm not sure I want to drop $6K for a used engine/install nor $2.5K for just a gasket, head resurfacing job.
I'm leaning to tackle the job myself and spend about $600-700 in parts, fluids, and resurfacing the heads. I'll look around on this site to see if anyone else had done this before or not. I figure it will take me 40 hours, maybe 50 due to my lack of experience to do this job.
