PolkManiac
I finally bought and installed the 06 Scion radio and noticed a significant improvement, but I'd still like to look at changing the stock speakers.
Looks like the rear doors are an easy swap, so I'll skip ahead to the front doors. I have a couple questions for anyone who's done the change...
1 - I know I have 6x9 and separate tweeters in my doors now. Are those setup like a typical component system with one set of wires coming from the HU into a cross-over from which wires run to each driver (6x9 and tweeter)? Or do I have a separate set of wires from the HU running the the 6x9 and the tweeter, treating them like independant speakers, and if that's the case does the receiver have a built in x-over to filter out the lower frequencies from that channel.
I hope that question makes sense...
2 - From reading on here, it appears that the general consensus is that there are no direct replacement drop ins. What about all the 6x9 speakers on the market - will none of them fit? I realize that 6x9 are not liked my many people, but I'll never be adding a sub to the mix, and the 6x9 should give me a bit more mid-bass than the 6.5, and I'll need that extra bass without a sub. I'd like to just add a 6x9 up there if it's at all possible...
3 - How deep are the stock 6x9 speakers, with magnet and all? is there anywhere online that I can find that info, or would someone mind measuring a pair they might have laying around. If I can figure out how deep my current 6x9 are, then I should be able to determine what will fit.
Thanks for all your help guys...
