2004 trailer hitch
leftyrb
My Canadian 2004 V8 SR 5 4Runner came factory equipped with the 7 pin trailer wiring connector as well as a 2" receiver hitch with a rubber plug. The manual indicates that the towing capacity is a maximum of 7000 lbs. The hitch appears to bolt to a rear crossmember with two bolts. Does this seem the common setup for towing this heavy a weight (weight distrivuting hitch required)?
