2005 4Runner Oil Plug
sjm1027
I looked under the vehicle and found an oval coutout around 4"x8" oval. and the 4x8 hole was covered by a plastic cover you just pop off. I want to change the oil but I have been reading that most of you drop the skid plate to do this. Why is that? Has anyone had trouble, is this oval hole not large enough?
Those that have to remove the skid plate probably have V8s, their oil filter isn't located on top where it can be easily reached like our V6s.:D
Great, yes I have a 6 cyl. So do you ever have a problem with oil getting mehind the skid plate?
The oil filter has this tube (Short) and a plug in it. I was thinking of hanging a cup there while I changed the filter. Looks like it could be a small pain.
Steve
Is the plug in the same place on a 2006 V6 4Runner...behind that plastic pop-off plate. I'd sure hate to drain the wrong fluid....
Well I sure hope so... There is nothing else there, why did you see anything else in that area?
JPNNH said:
Well lookin under there I see three seperate plugs but one distinct plug under the pop-off plate!
I couldn't get right under it I could only feel one plug very close to the plastic door. Maybe someone can help us
I changed my 4Runner's oil yesterday. It is a V6, with the little oval plastic plate in the skid pad - and the oil filter on top of the engine.
Anyway, you can pop off that little plastic cover with your fingers - or you may need a screwdriver. There are six "fingers" which will bend and let you snap it off to access your drain plug. You may need a socket extension, though, since the plug will be about 1 /2 inches or so behind the oval hole.
To snap it back on, try putting in the front-facing fingers first and then click the back ones. Never had trouble doing it that way.
The filter will be easy, but be sure to use a little plastic bottle to catch the oil which will drain out of your filter when you unscrew it. There will be about 8 ounces or so of dirty oil that will be in the little reservoir by the filter. Just don't forget to replace that little rubber plug after you put in the new filter. It keeps any extra oil from leaking down onto your engine block or valve cover.
This is one of the easiest vehicles for changing the oil. You'll need 5 1/2 quarts if you replace the filter (which you should always do at every oil change). Don't forget to grease your chassis (six fittings on the 4x4, three on the 4x2) every so often.
Nice write up,
Thanks for the help, very clear... Do you know where I can find where these 6 fittings are? Nothing in the manual.
Thanks again
Steve
Grease Fittings
There are six fittings (4x4), and three on the 4x2. This is because the four-wheel-drive models have two drive shafts -- or propeller shafts, as Toyota calls them.
I posted an inquiry a few months back, and someone (sharp4runr, I believe) posted a diagram of where they were. He was exactly correct and I found them rather quickly.
If you are under the vehicle, look at the rear axle. There will be a u-joint thing where the driveshaft meets it. That end has two fittings on it - one that is easily seen, and another that is sort of "inside" the area where the pieces meet. The other end of the driveshaft closest to the transfer case will have just one fitting.
If you look at the front propeller shaft, the end closest to the transfer case will have one fitting, while the end closest to the front differential will have two -- pretty much a mirror image of the other driveshaft.
Toyota recommends two different types of grease, so I just use the best type (synthetic - about $4 per tube) on all of the fittings. One tube will last you quite a long time, so don't worry about spending an extra buck or two. After all, it is a 4Runner and you don't want to be but so cheap.
:awais:
Good luck to you; and don't be a dumbazz of the day like I was. Go and read my post from Sunday about that.
:beer:
P.S. This is best done with a grease gun that has a flexible tip and which can be pumped with one hand. Typically, you will need your other hand to hold the tip of the grease gun on the end of the zerk (fitting). Be sure it "clicks" into place and that you can see the grease squirt out through the adjoining pieces and not all over your hand!
Steve
I have found that an empty 1-quart oil bottle works just fine to put under the drain port to catch any old oil that leaks from the old filter when removing it. I use a paper towel to mop up any that doesn't drain out before I install the new filter. If the new filter is installed properly, there shouldn't be any further oil to worry about. As for that small plastic cap for the drain tube, I've lost mine quite a while ago, and frankly don't miss it.
I also get the floor jack out and jack up the passenger side about 5 inches to make life easier under my Runner. Those 4x2's sit way to close to the ground.
So is the oil plug under this plastic door in the skid plate. The plug you can feel about 1/2 inch in? I think someone said 14mm?
I think I am all set. Looks like Toyota won't be charging me $44.00 any more.
Its so easy you will suprise yourself. If the oil container doesn't fit underneath, just jack up one side and it make it a ton easier.
make it really easy on yourself.
Want to make it really easy on yourself?
Get a Fumoto valve and pop that in on your next oil change. They are about $20.00 - $25.00. You'll have a no-mess 8 minute DIY oil change on your Runner :)
Use a F-103 valve (no nipple) or a F-103N (with nipple). I used a F-103N and attached a small piece of tubing to it that I stick in the drain pan. I just stuff it up inside the skid plate when I am done.
J-L
I just went to the site, looks pretty interesting I must say. So if I used a F-103N in a 2005 4Runner will it clear the little door on the skid plate? Or would I have to drill a nipple hole :biggrin2:
Has anyone out there used one of these drains?
Steve
I also use the FRAM and it works great. I believe it is cheaper than the Fumoto and you can find it at the auto parts store.
