2005 4Runner v6 4WD scheduled maint guide
rgcary
While looking through this it does not list that I need to change the differential fluids or transfer case fluid? It also does not say to replace the timing belt or chain for the '05 4Runner v6 engine 1GR-FE. It does say change the diff fluids if you have limited-slip, if equipped, but again it does not list the 4Runner in the footnote.
It is my understanding that you're supposed to change the diff AND transfer case fluids every 30,000. I did this at 35,000 and now I'm due again. I switched to synthetic fluids at 30,000 for the diff/transfer case back then. What about the timing belt or chain at 90,000 for the v6?
Toyota is WAY too busy with these recalls to bother with this...
Thanks for you help.
Rick
Rick
Your correct... The way I read this you have 60k or so on the synthetic presently in the t-case and axles. I would change it again. Your '05 Runner is now 5. I'd change the coolant and trans fluid too. Finally on the V6 no need to do anything with the timing chain but I would put a set of spark plugs in it. The plugs are 30k items unless you swapped to long-life plugs at some point.
Thanks.
Chris - I have 64,000 now and yes, I'm just about due to change the diff/transfer case fluids again. I did the plugs already and Toyota does not recommend the long life in the V6 engine from what I was told. I wanted to do this, but they said not a good idea. Oh well. As far as the coolant and trans fluid I was informed that the coolant is long life (100,000 miles) and the transmission is sealed, no filters, etc and does not need changed. I'm not used to this type of limited maint, but what I have read in the owners manual and on-line it's true unless I'm not understanding something correctly.
So does the v6 have a timing belt or chain? It's a ways off for 90,000, but in the past on other vehicles I have changed the "belt" and water pump around 90-100,000 miles and it seems the v6 4Runner does not need this.
This is a pretty good site to get info from and thank you again for your input.
Toyota Parts and Service
The V6 uses a timing chain, no regularly scheduled maintenance for it.
And of course our 4Runners use non-silicate coolant (from the 2004 model year and up), so the water pump shouldn't leak early either. And you're correct about the 100,000 mile change interval for the coolant. Basically, you should have no worries about the timing chain or water pump or coolant with the V6. Sweet, huh?
Thanks! That is SWEET! Saves some green too! Now I'm just waiting for my vehicle tax bill to hit me this year! Ugh.
On the anti-freeze, IMHO, I care less about miles than age. I would consider doing it no later than in it's 7th year. It's comparatively cheap and why not.
Transmission: Toyota says "for life" unless you tow, then it's 60k (see this link http://smg.toyotapartsandservice.com/index.php ). The WS fluid is good stuff but not that good IMHO and several FJC guys agree (look around their forums). The links below explain some of it including the fact the transmission is not sealed, it just fills differently.
http://www.toyota-4runner.org/maint...ission-fluid-servicing-sealed-non-sealed.html
http://www.toyota-4runner.org/4th-gen-t4rs/53168-ws-transmission-fluid-stands.html
