2005 4runner v8 2wd - 100K timing belt/fluids/shocks
I am new to this forum but have been researching for a while before I posted. I have a 2005 4runner V8 2wd and have read so much different stuff on the 100k service. I bought mine used from toyota w/ 67k on it, so Im not sure what has and hasnt been done. I would rather err on the side of caution and be more preventative since I want to drive this sweet ride for much longer. Below are what I was thinking about doing and would be very appreciative for some insight:
Timing belt - def doing - was looking to buy a kit on ebay from aircabinman and have a mechanic friend do the work - he recommended that I buy the belt directly from toyota?
**changing the idler roller / tensioner roller / water pump and gaskets - anything else needed? Kit say it comes with hydraulic tensioner (what is it)?
What about the following:
serpentine belt
thermostat and t-stat gasket
front crankshaft seal
front camshaft seals
Fluids: (like I said not sure what has been done before so think to start fresh)
differential? - since its 2wd only a rear, right? What kind and how much needed?
transfer case? - what type and how much is recommended - seems I see amsoil and redline named in these forums
Transmission FLuid - drain/fill or flush/fill - I think its a sealed tranny with ws fluid. Any certain brand recommended? Synthetic?
Spark Plugs - Iridium - deciding between NGK and Denso - prob NGK and will be doing this myself.
Fliters - already had an oil change and changed out the cabin and air filter
Shocks - starting to get a bit bouncy and Im an outside sales rep so I drive all day every day. I also haul bikes/bike racks around constantly (up to 4 bikes - so maybe 200lbs total). Some towing as well.
**looking at the bilstein HD's and found em for $300 (for all 4) shipped on shock warehouse. Ive read some people saying they are longer than the stock and will not ride properly with that stock springs? Bilstein says they are not going to create issues? Any thoughts? Any other recomendations for shocks?
Any input and thoughts are greatly appreciated and hopefully this will help out many others who are in the same situation.
serpentine belt
