2005, Blown fuse?
FunnerRunner
My 2005 Limited has lost one-half of its lights on the center lower panel's right side. The one that displays the temperature, etc. I've checked the fuses but cannot locate which one may be associated with the problem. I'm not sure if there even is a fuse, or just some sort of LED that may have failed. Your thoughts
there are 3 little lights behind the display that have probably gone out. happened to mine and prolly a few others. all that needs to be done is to replace them. better do all three at the same time.
FunnerRunner said:
thanks ndryden123, is this a do it yourself thing or is it a job for the dealer?
I did it myself. You have to take the center console apart to get to the climate control. Its very straight forward. There is a link somewhere on here that tells you how to take it apart. I believe it is in the Audio/Electronics part. If I sent you in the wrong direction with that one Im sure someone will tell you exactly where it is. You have to order the lights from a dealer. I think I paid like $8 dollars or something like that for all three. But its something that you can do by yourself. Let me know if you run into any snags.
