2005 Jeep Liberty (Refreshened)
Thai
Elite Member
NEW 2005 JEEP LIBERTY STANDS APART
FRESHENED EXTERIOR AND REFINED INTERIOR ACROSS THE LINE
JEEP LIBERTY RENEGADE MODEL FEATURES MORE RUGGED APPEARANCE
JEEP LIBERTY FEATURES FIRST DIESEL IN U.S. MID-SIZE SUV SEGMENT
Jeep Liberty will offer the first diesel in the U.S. mid-size sport-utility vehicle segment, adding unique capability in support of the Jeep brand
Pics
2005 Jeep Liberty Diesel and Six-Speed Manual Information
Auburn Hills, MI - The 2.8-liter CRD is among today's advanced diesel engines that emit 60 percent less emissions than diesel engines of 20 years ago," said Craig Love, Vice President - Rear Wheel Drive Product Team and Core Team Leader. "Additionally, the noise, vibration and harshness issues that plagued older diesel-powered vehicles have been dramatically reduced in the Liberty diesel. The result is that the legendary capability of the Jeep Liberty reaches a new level of performance with the 2.8-liter diesel engine."
The Jeep Liberty is the first mid-size sport-utility vehicle available with a diesel engine in the U.S. The 2.8-liter CRD boasts three best-in-class stats: 295 lb-ft of torque (400 Nom) @ 1,800 rpm; driving range of approximately 500 miles; and towing capacity of 5,000 pounds. The engine produces 160 horsepower and gets an estimated fuel economy of 22 miles city and 27 miles highway.
The 2.8-liter CRD is an enhanced version of the four-cylinder diesel engine currently offered on this vehicle in Europe. VM Motori, which is owned in part by Detroit Diesel, a DaimlerChrysler company, is the manufacturer of the engine. VM Motori has been supplying the Chrysler Group diesel engines since 1992 for minivans and Jeep products sold in Europe.
The 2.8-liter diesel uses an advanced common rail direct injection fuel system. Direct injection of fuel into an open combustion chamber is more efficient than a pre-chamber indirect injection configuration. The system in the 2.8-liter CRD operates at fuel pressures nearly 70 percent above the older distributor pump systems, producing finer atomization, leaner combustion and higher power. At the same time, direct injection provides inherently lower engine-out hydrocarbon exhaust emissions and lower NOx emissions. A high pressure pump driven by the cog belt from the camshaft supplies fuel at up to nearly 24,000 psi. The pump's electronic control system responds to fuel demand and delivers the optimal fuel pressure, injection timing and injection duration.
Injectors on the 2.8-liter diesel have been improved so that fuel burns more thoroughly, producing fewer particulates and lower emissions than previous generation diesel engines.
An electronically controlled variable geometry turbocharger improves control of boost pressure, reducing emissions and improving full load engine power and torque. The turbocharger features moveable vanes that allow it to act like a small turbocharger under launch conditions. At higher engine speeds it acts like a larger turbocharger. The benefit to customers is enhanced low-end and high-end torque. Meanwhile, a vacuum reservoir improves cold launch performance by allowing the turbo to spool up faster from idle, which minimizes turbo lag.
The Liberty diesel engine uses two pilot injections prior to the main injection. This system prepares the cylinders for the main injection of fuel, which helps to smooth out the main combustion and quiet the engine, especially at idle.
In another improvement, the 2.8-liter diesel uses electronically controlled ceramic "smart" glow plugs with a warm-up time of only two seconds. They assist with low ambient temperature start conditions and only glow when needed. This is an advance over older, timer-operated glow plugs that require up to 10 seconds of warm-up prior to engine start.
SIX-SPEED MANUAL TRANSMISSION
The 2005 Jeep Liberty features the NSG370 six-speed manual transmission, replacing two, five-speed manual transmissions previously used - the NV1500 and NV3550. This new transmission is a member of the six-speed NSG370 family, similar to the one used in the Chrysler Crossfire, the first six-speed for the Chrysler brand. The NSG six-speed manual transmission provides a 4.46:1 first-gear ratio, versus the 3.85:1 and 4.04:1 ratios of the five-speed transmissions it replaces, for improved launch and traction. It also provides close-ratio gear performance in the intermediate gears.
The NSG370 six-speed manual transmission provides optimal shift quality, improved quietness and high quality. A new dual-ratio transmission shift-tower system allows packaging of the six-speed shift pattern within the existing Jeep vehicles, and is tuned for optimized shift quality. For smooth operation the first and second gears have triple-cone synchronization, the third and fourth gears feature double-cone and the fifth and sixth gears single-cone synchronization. Hard-finished gears allow for quiet operation. A multi-rail, steel-construction shift system delivers high strength and precision. The two-piece aluminum case with integrated clutch housing assures powertrain stiffness and light weight. The new first-gear ratios combined with six-speed step spread allow optimization of axle ratios for fuel economy and performance.
The Jeep version of the NSG370 transmission has passed the rugged durability testing required of all Jeep driveline components.
2005 Jeep Liberty Communication and Entertainment Systems
Auburn Hills, MI - For motorists who desire top-of-the-line communication systems, the 2005 Jeep® Liberty has the equipment to fit the bill. Simple-to-use and hassle-free technological advancements in vehicle entertainment add to the driving experience of the 2005 Jeep Liberty.
“The Chrysler Group’s vehicle communications strategy places an emphasis on creating a safe driving environment through practical innovations, while enabling customers to choose the services they want,” said Jack Withrow, Director, Vehicle Entertainment Communications. “It’s all about simplicity, safety, freedom and flexibility.”
RB1 NAVIGATION RADIO SYSTEM
The RB1 factory-installed Navigation Radio system is housed in the center of the Jeep Liberty dashboard, which allows for easy access for both the driver and passenger. The 4.2-inch full-color display features AM/FM stereo, CD player and navigation system in one unit. Utilizing voice commands, the system guides the user through the drive route, mile-by-mile, turn-by-turn until the final destination is reached. Destinations can be entered into the system eight different ways and the screen can be viewed as a detailed map or enlarged to be viewed turn-by-turn. When coupled with SIRIUS™ Satellite Radio, the stream listing, stream category, song title and artist can be viewed on the system’s display screen.
The RB1 Navigation Radio was offered as a Mopar® dealer-installed option on 2004 Chrysler, Dodge and Jeep vehicles. The first factory-installed option was available on the 2004 Jeep Grand Cherokee and 2005 Chrysler 300. Factory-installation cost varies from $1,200 to $1,500, based on equipment package and content. Pricing for the dealer-installed version of the RB1 Navigation Radio is $1,595 (suggested retail price) plus labor.
Chrysler Group selected Alpine Electronics, a supplier of high-performance mobile electronics systems, to provide the navigation unit, GPS antenna and map database information. The map database information is housed on a single DVD-ROM based on NAVTECH data.
UCONNECT HANDS-FREE COMMUNICATION SYSTEM
The UConnect hands-free communication system uses Bluetooth® technology to provide wireless communication between a customer’s compatible cellular telephone and the vehicle’s on-board receiver. Bluetooth is a short-range wireless networking technology that connects two or more devices together. As the number of drivers using cell phones increases, hands-free, voice-activated options are a way to connect a driver to a cell phone call more safely. The Chrysler Group was the first North American automaker to offer its customers a Bluetooth-enabled automotive dealer-installed application last year.
The factory-installed version allows the audio to be heard through the vehicle’s radio speakers. A control pad and microphone are housed in the vehicle’s rear view mirror serving as the driver interface. UConnect factory installation is $275 and available on the 2005 Jeep Grand Cherokee as well as many other 2005 Chrysler Group products.
UCONNECT FEATURES THE FOLLOWING:
• Voice dialing - Voice commands can be used to digit-dial the phone
or access pre-stored voice tags
• Audio address book – Enables customers to store up to 32 names, four
numbers per name, for a total of 128 phone numbers
• Audio system mute – Mutes the microphone for privacy
• Call transfer – Allows the customer to transfer a call from the vehicle’s
system to the mobile phone
• Communicates in three languages – French, Spanish and English
• Multi-phone recognition – Up to five phones can be used within the vehicle’s system UConnect is available as a dealer installed option. Dealer installation is $299 (suggested retail price) plus labor, and can be installed in all Chrysler, Dodge and Jeep vehicles back to 1994, excluding Jeep Wrangler, Sebring Convertible and Chrysler Crossfire Convertible.
SIRIUS SATELLITE RADIO
SIRIUS provides Chrysler, Dodge and Jeep customers with 100 streams of the best music, entertainment and information coast-to-coast. SIRIUS offers 60 music streams of commercial-free music along with 40 sports, news and entertainment streams, 24 hours a day.Consumers selecting the SIRIUS Satellite Radio option will receive a small, mouse-sized antenna mounted to the roof of the vehicle. They will be able to scan channels and select pre-set buttons for favorite channels. Consumers will also be able to search both by music category and channel, which will be displayed on the radio screen.
The Chrysler Group offers SIRIUS Satellite Radio as both a dealer- and factory-installed feature. Factory installation for 2005 model year Chrysler Group products is offered at $195 (suggested retail price) and includes a one-year SIRIUS subscription. The suggested retail price for the dealer installation is $299 plus labor, in addition to a SIRIUS subscription of $12.95 per month.
2005 Jeep Liberty Noise, Vibration and Harshness Improvements
Auburn Hills, MI - To reduce the NVH levels of the Liberty diesel, Jeep engineers made dozens of improvements affecting the engine and body-in-white. All of these improvements can be classified in one of three types: the source of the NVH, the structure of the vehicle and acoustics.
Source - Since the engine is the primary source of undesirable NVH levels, improvements to the 2.8-liter turbo diesel include engine balance shafts, a new noise-reducing engine cover, and a torque converter turbine damper. Also, an air induction resonator reduces induction noise emissions.
Structure - The structure of the Liberty was also reengineered. Improved engine mounts, called hydro mounts, function in a manner similar to shock absorbers. The fluid within the mounts provides isolation and damping, which reduces the amount of vibration and harshness that reaches the body. In another application, the dash, plenum and the body-in-white panel consist of a dampening material sandwiched between two metal layers. This process of stiffening and dampening the sheet metal reduces the amount of noise that travels into the vehicle.
Acoustics - Airborne noise is kept from the passenger compartment of the Liberty diesel in a number of ways. For example, an acoustic belly pan is attached beneath the engine to absorb its noise. Noise is also absorbed via an engine compartment hood liner. And the cabin contains noise-absorbing carpet.
"The 2.8-liter turbo diesel engine performs better and pollutes less than previous diesel engines, while delivering reduced NVH levels," said Love. "In tandem with the proven capability of the Jeep Liberty, this engine gives sport-utility owners and prospects an exciting new driving opportunity."
2005 Jeep Liberty Overview and Features
Auburn Hills, MI - Since its introduction in 2002, the Jeep® Liberty has captured the attention of Jeep owners and attracted a new generation of sport-utility vehicle buyers who value the best combination of Jeep 4 x 4 capability and on-road refinement in the mid-size sport-utility segment. The vehicle has garnered nearly 75 percent new buyers to the Jeep brand, while still appealing to traditional Jeep 4 x 4 owners.
For 2005, the Jeep Liberty unveils a new freshened exterior and interior design on the Sport and Limited models, and the Liberty Renegade takes on a more rugged design with its unique exterior. Also new to the lineup for 2005 are a six-speed manual transmission and the first turbo Common Rail Diesel (CRD) engine offering in a mid-size SUV for North American markets."Jeep Liberty's refreshed interior and exterior help to solidify the vehicle's leadership position in the marketplace while staying true to its Jeep heritage," said Jeff Bell, Vice President - Jeep. "The 2005 Jeep Liberty offers the best combination of Jeep 4 x 4 capability and on-road refinement in a mid-size SUV." JEEP
LIBERTY DIESEL (read more about the CRD here)
For the first time in the U. S., the Jeep Liberty will be offered with a 2.8-liter CRD engine, giving its customers state-of-the-art technology that fits their lifestyle. The 2.8-liter CRD is equipped with a five-speed automatic transmission on the Jeep Liberty Sport and Limited models. Providing class-leading torque and towing, the diesel engine will attract yet another type of buyer to the Jeep Liberty. The 2.8-liter CRD engine is rated at an estimated 160 horsepower (120 kW) at 3800 rpm and with 295 lb.-ft. (400 Nom) of torque at 1,800 rpm for unmatched towing power (5,000 lbs.). Diesel engines offer another option for increased torque, towing and range, while improving fuel economy an average of 30 percent and reducing CO2 emissions by an average of 20 percent.The 2.8-liter CRD is an enhanced version of the four-cylinder diesel engine currently offered on this vehicle in Europe. VM Motori, which is owned in part by Detroit Diesel, a DaimlerChrysler company, is the manufacturer of the engine. VM has been supplying the Chrysler Group diesel engines since 1992 for minivans and Jeep products sold in Europe.
"The new diesel engine delivers the torque of a V-8, the performance of a V-6 and the fuel economy of a four-cylinder engine," said Craig Love, Vice President, Rear Wheel Drive Product Team and Core Team Leader. "We always say Jeep is the go-anywhere, do-anything brand, and these features give our owners even more capability to do just that."
Appealing to a slightly different type of buyer than the Sport and Limited models, the Jeep Liberty Renegade features a flatter hood that complements the traditional round Jeep headlamps for a distinctive appearance. A body color grille is also new for 2005. Large freestanding fog lamps with black bezels offer more visibility when off-roading and a new sill protects the body sides from road blast. Tow hooks and a Bright Silver Metallic appliqué across the new molded-in color front fascia are standard features. Bolted flares are also molded-in color for more durability and feature chrome-plated attachment details. A new luggage side rack with beefier molded-in color structural end pieces and a Brushed Silver Metallic tubular side rail enhances the Renegade's rugged appearance. The black off-road light bar is now an optional feature. Fender flares combined with available all-terrain tires, off-road light bar and taillamp guards give the Liberty Renegade a look that stands apart from the Sport and Limited models.
JEEP LIBERTY RENEGADE STANDARD FEATURES
• 3.7-liter V-6 engine mated to a six-speed manual transmission
• Command Trac
• Independent front-and-rear suspension
• Rack-and-pinion steering
• Four-wheel disc brakes
• 16-inch metallic cast aluminum wheels
• Rugged tubular side rails
• Molded-in accent color fender flares
• Body-color grille
• Rock rails
• Silver mini carbon shifter and center stack bezels
• Six full-range speakers
• Leather-wrapped steering wheel
• Advanced multi-stage driver and front passenger air bags
• Occupant Classification System
• Tire pressure warning
JEEP LIBERTY LIMITED
A chrome grille, chrome body-side molding - with the LIBERTY name molded in - and chrome side rails are new design cues for the 2005 Jeep Liberty Limited. Accenting the vehicle are painted body color front and rear fascias and bumpers. Fog lamps are standard on the Jeep Liberty Limited and tow hooks are available with the Skid Plate Group package. The Limited also features a new sill to protect the body sides from road blast.
JEEP LIBERTY LIMITED STANDARD FEATURES
• 3.7-liter V-6 engine mated to a four-speed automatic transmission
• Command Trac
• Independent front and rear suspension
• 17-inch sparkle silver cast aluminum wheels
• Satin silver shifter and center stack bezels
• Six-way power driver seat
• Premium door trim panels
• Cloth low back reclining front bucket seats
• AM/FM stereo with CD
• Body color fender flares
• Bright chrome grille
• Bright side rails
• Spare tire cover
JEEP LIBERTY SPORT
A new body color grille with a full Jeep shield includes provisions for optional fog lamps on the new Jeep Liberty Sport. The higher fog lamp and park/turn lamp locations on the vehicle offer more protection from road debris. The new front fascia remains molded-in color with a crisper, more horizontal shape to provide the Liberty Sport with a wider, more stable appearance. The Sport also features a new sill to protect the body sides from road blast. The front bumper runs across the bottom of the grille with a twin-tube appearance to create a custom accessory look. Interior refinements on the vehicle include relocated power window switches that are easier to access and operate. New instrument cluster graphics - white letters on gray background - provide greater visibility at twilight and dusk and give a more refined look. On-road refinement gets an assist from new seats that are improved through the use of dual density foam. In addition to being more comfortable, the seats have a more contemporary look with new contours; new styles and fabrics, including a new "diamond-plate inspired" seat fabric. Additionally, the rear seat fold angle of the vehicle is reduced, providing a flatter load floor for increased utility and improved cargo storage. A new six-speed manual transmission replaces the previous five-speed manual transmission. The new NSG370 six-speed transmission offers improved quality and Noise, Vibration, and Harshness (NVH) specifications. It is available on the 4 x 2 and 4 x 4 Sport and Renegade models. "The Jeep Liberty is uniquely positioned to deliver both the refinement required by this expanding market, while also offering the toughness of the legendary Jeep brand," said Bell. "The Jeep Liberty stands apart from the next generation of less capable mid-size sport-utility vehicle offerings."
2005 JEEP LIBERTY SPORT STANDARD FEATURES
• 2.4-liter I-4 engine mated to a six-speed manual transmission
• Command Trac®
• 65/35 split folding rear bench seat
• Tilt column steering wheel
• Remote keyless entry
• 12-volt power outlet located in center stack
• 29.0 cu. ft. cargo volume
OPTIONAL FEATURES:
• 2.8-liter turbo diesel engine (Sport and Limited models only) mated with five-speed automatic transmission
• Select Trac® full-time 4-wheel drive
• Four-wheel anti-lock brakes
• Supplemental side-curtain air bags
• Tire pressure monitoring display
• Leather seats
• Heated driver and front passenger seats (leather seats only)
• Six-way power driver and passenger seat (leather seats only)
• Electrochromic interior rear view mirror
• UConnect™ hands-free communication
• Infinity® premium speakers, six
• DVD Navigation radio with integrated six-disc CD player
• SIRIUS™ Satellite Radio
• Off-Road Package with tow hooks and skid plates
• Light Bar
All Jeep Liberty four-wheel-drive models will wear the Jeep Trail Rated® badge. The Jeep Trail Rated badge shows that the vehicle has been designed to perform in a variety of challenging off-road conditions identified by five key consumer-oriented performance categories: Traction, Ground Clearance, Maneuverability, Articulation and Water Fording.
Jeep Trail Rated is an industry-leading methodology established by the Nevada Automotive Test Center (NATC) and Jeep Engineering to objectively measure and consistently predict off-road performance for all Jeep vehicles today and into the future. Through a combination of natural and controlled field tests, as well as computer simulated environments, Jeep Trail Rated provides a repeatable and consistent measurement of off-road performance for all Jeep vehicles. Only Jeep vehicles are Trail Rated. The Jeep Liberty is manufactured in Ohio at the Toledo North Assembly Plant.
Jeep Announces Liberty CRD Pricing
Boston, MA - In a speech today during press days at the New England International Auto Show, Jeff Bell, Vice President - Jeep, announced pricing for the 2005 Jeep® Liberty Common Rail Diesel (CRD), the first diesel-powered mid-size sport-utility vehicle in the U.S. The new 2.8-liter turbo diesel engine delivers the torque of a V-8, the performance of a V-6 and the fuel economy of a four-cylinder engine.
The base Manufacturer's Suggested Retail Price (MSRP) for the Jeep Liberty CRD Sport 4x4 is $25,125, including $610 destination. The base MSRP for the Jeep Liberty CRD Limited 4x4 is $27,355, including $610 destination. The Jeep Liberty CRD will begin arriving in dealerships later this year.
"Response to the new Jeep Liberty CRD has been huge," said Bell. "Nearly 40,000 consumers have expressed interest in the diesel-powered Jeep Liberty, well ahead of the manufacturing launch in November. Jeep vehicle owners and prospects understand that the Jeep Liberty CRD is another go-anywhere, do-anything option from Jeep that will help them enjoy their active life-styles."
The Liberty diesel is a technologically advanced powerplant designed to be an efficient, smooth, clean-running engine that produces lower carbon dioxide (CO2) emissions without sacrificing performance. The engine produces 160 horsepower and gets an estimated fuel economy of 22 miles city and 27 miles highway. The 2.8-liter diesel gives the Liberty best-in-class numbers in three categories: 295 lb-ft of torque @ 1,800 rpm; driving range of approximately 500 miles, and towing capacity of 5,000 lbs.
05 jeep liberty
my uncle just bought a liberty in 10 days the tranny went, it was gasoline though.
I guess it happens I know my 4runner is running fine.
It will be real hard for me to buy a american suv again
Just love Toyota so far 30,000 miles and running
