2005 - power steering fluid leak
rsco
I have a 2005 T4R. I was driving and my serpentine belt slipped off the pullies and damaged itself during a turn. I replaced the belt the next morning and it drives fine but, I have a power steering fluid leak. It will leak when the engine is off and the wheels are strait (enough to drain the reservoir overnight. I used some tracer dye and a uv light. It is leaking somewhere between the shaft on the power steering pump and the wheel/pully on that pump. Is there a seal in there? Is the pump damaged? Any suggestions are appreciated . Thanks!
