2006/2007 headlight
wieyu
Hi folks, sorry I've been off-line coz of work
Just want to find out from our Pro's if it's possible for me to install a 2006/2007 headlight to my 2004 4Runner? Do I need to do any mods? Any help would be really appreciated. Thanks.
It would take a lot of modding. DRL's, grill, and headlight shape are all different. I think somebody may have addressed this topic a while ago but I can't find it.
2004 4Runner
Thanks for the reply. That's a lot of mod to do. I'm thinking of just changing my bulbs to HID bulbs (9006) from xenondepot and maybe I'll be satisfied. What do you guys think?
Re: 2004 4Runner
That should do the trick! It is much easier than changing the entire casing.
You can change them to projector lights from the 2006+. You will need the lower trim under the headlight to complete the mod. There will be a small triangular gap due to the different grille shapes between the 2003-05 and 2006+. You also need the new wiring harness, because the 2006+ uses H11 bulbs for low beams.
Check out this thread. It's a 2005 with the 2006+ headlight swap. Page two shows the gap created by the different grille shape on the 2006+.
2004 4Runner Headlight conversion
Thank you so much for the info guys. It help me a lot. Another question though, I hope you guys are not getting tired of my topic yet. If I ever decide retrofit to 06-07 headlight, how much is the lower trim of the headlight would cost me and what is the name for this part of the headlight assembly? Thanks.
