4gin007
I have a 2006 2wd 4runner v6 with 150k miles on it. Last time I changed the oil I noticed a huge mess under the truck on the skid plate below the oil pan. I changed the oil drain plug to no avail. It seems to leak a quart every 2 weeks. It appears that the leak is starting above the oil pan on the rear of the motor, the front of the pan is dry, as is the front of the motor. I would say oil residue starts 3 inches above the pan.
http://www.toyota-4runner.org/4th-gen-t4rs/93770-new-oil-leak.html
this is the only thread that seems similar to what the 4runner I have is experiencing. But this thread is confusing and doesn't have a solid conclusion.
What do you guys think? Im leaning away from the oil pan gasket because as mentioned before theres wet oil above the pan. Ill be taking a closer look at the truck in a couple weekends, right now Im looking for ideas of things to look at.
