Does anyone know if the 2006 head light will fit a 2003 model.?
I have an sr5 v8, if this helps? I would rather have oem parts than aftermarket.
Dan:shrug:
Dan:shrug:
Some guys have already done the swap. They do fit, but not perfectly. The grille and the edge of the light housings don't line up perfectly. Also, the trim piece below the headlights will have to be changed to match the '06 housings. Plus, you'll have to modify the wiring a little bit to make them functional. But it can be done.
