2006 RWD Differential Whine
Put the rear of the vehicle on jack stands. Let it idle in drive. Take a mechanics stethoscope and touch it to the axle housing under the wheel bearings and the pinion gear and other points too. You should be able to hear where the noise is coming from. Ours was unfortunately the differential bad.
Replaced the third member with a rebuilt from ECGS yesterday. Easy with the above linked instructions. Hardest was getting the new unit lined up and supported - heavy! And, unlike the above linked instructions, I disconnected the brake line and bled afterwards - easy and no problem pulling axles out enough.
And the best part - quiet as a church mouse now! I’ll follow their break instructions to ensure longevity. I can’t see any damage or wear on any of the old components, hopefully ECGS will let me know the cause to satisfy my curiosity...
Glad to hear you got it fixed, I'm guessing it's the pinion bearing that was causing your whine, I have a very similar whine as well but I'm going to wait until it gets worst to swap mine out, it's been about the same ever since I bought it almost 3 years ago.
I will be interested in hearing what they say is the actual issue on your old 3rd member, what did you end up paying, if you don't mind me asking?
That being said I hope you didn't use the 27 ft. lbs. for the torque on the axle backing plate nuts, I'm not sure what the actual proper torque is but if you read all the replies in that writeup you would have seen where he was questioned on this, and he thinks it's different for disk brakes and he has drum brakes, might want to check on that if you haven't already because from I read it could be much, much higher torque, around 97 ft. lbs. possibly.
Yeah, I went back through the service manual printouts and see 48 and 91 ftlbs from two different pages for the torque on the axle backing plate nuts. I think I torqued to 48 and added blue loctite. I think I’ll go back and redo to 91 ftlbs to be on the safe side...
I would do more research before retorquing, it's just as bad to over torque to much, in this case as you're saying almost twice the torque at 91 ft. lbs. and the backing plate bolts may not handle that much torque, if that's incorrect and it's actully 48 ft. lbs. you risk the bolts breaking under stress.
I'm not sure why you would find 2 different torque values out of a Toyota shop manual, something isn't quite right there.
delislerebecca
