2007+ Audio Aux Pin Out
asanelli
Does anyone know the pin out for the audio aux headphone jack in the center console?
I want to try to integrate the aux function into a fully functioning usb interface that will provide and audio.
The connection should be a 4 pin connector with the following leads (ground, data+,data-,power). However I want to confirm this so i can integrate into a usb....
Does this help? It's from the EWD.
Yes that works.
You don't to have a legend for what the wires are?
I assume they are the following.
ALO: Data Low
ARO: Data High
ASGN:Ground
AUXO:Aux
Any thoughts??
EWD is Electrical Wiring Diagram, a factory service manual just for the entire electrical system.
Pretty sure they are Analog Left channel Out, Analog Right channel Out, Ground and Aux out. Unfortunately I don't know enough about this stuff in regards to 'data' signals.
The 4th manuals are all available online. I don't know about 5th gen stuff but they probably are.
Not sure what you are doing but keep in mind there is a signal wire that tells the head unit something is plugged in. I had one go bad and the HU wouldn't switch to aux. If you are modifying it in someway, you will need to trick it.
