2007 Tacoma Alloy rims on 4Runner?
daugherty83
Wheels and tires found for $500. Was their a cutoff year for no longer fitting our 3rd gens? These look really good and seem like a decent price. I need new rubber as well so this would take out two birds with one stone. Any thoughts?
as long as its at least a 16" 6 lug wheel (6 on 5.5) and came off of an ifs truck then you should be good. -those wheels will fit. all toyota 4x4(except the new land cruiser, tundra and sequoia -2007-current) are 6 on 5.5 lug pattern.
I had a set of those, but sold them (for $300).
They will fit (a couple guys have done that), but they have more backspacing than the stock wheels, so you won't be able to go bigger on tires without rubbing. I think they are about 5" BS.
I got a set of those 07' Taco rims for free and I want to put them on my 99' T4R. What size/type spacer do I need to run 285/75/17? I've seen alot of guys using a 1.25" spacer on our stock 4.5" BS rims so would I need to go with a 2" spacer?
All 6 lug Toyota rims will fit eachother. All 4Runners, Fjs, Tacomas, and the previous generation Tundras.
I know that all 6 lug toyota rims use the 6x5.5 but my concern is the back spacing. If those 07 taco rims have a 5" back spacing then you would have less room between your UCA's if you were running 285's? or would having a back space of 5 versus 4.5 give you more clearance for 285's?
rubbed so bad on mine i couldn't drive it without 1.25" spacers. Check out my build thread for pics. of them on a toytec 3.5" with 285's
I want to run the same size tire and rim that your running. Is the 1.25" spacer enough or would you recommend a 1.5" spacer? Besides the UCA's did you have any other rubbing issues? I'm expecting to trim some of the plastic valance in the front.
