Build the perfect overlanding setup today and enjoy freedom without limits
WHEELSFEELS
official vendor
With our Advanced Storage & Camping System for 4th and 5th generation Toyota 4Runners with two rows of seats, weather will no longer stand in the way of your automotive adventures.
The sturdy sliding drawers can hold up to 150 pounds each, with one large drawer supporting up to 250 pounds. The top lids easily transform into convenient platforms for a cooler or quick access to your gear, adding freedom and comfort to your trips.
The sleeping platforms can be set up in just three minutes. When the second-row seats are folded down, you get a spacious sleeping surface that can be easily expanded using additional modules and by removing the lower cushions of the second row.
Our system is fully customizable to fit your needs. Choose drawer heights of 5, 7, or 10 inches, and add dividers, a table, a sink with a faucet, lighting, and fridge mounts. You can select a waterproof plywood finish with a glossy coating or black carpet material.
Every component has been carefully designed by engineers in collaboration with 4Runner owners, and assembly takes only 10 to 15 minutes. Additional moisture protection, noise damping, and thoughtful construction prevent squeaks and rattles.
With the Advanced Storage & Camping System, your trips will turn into true adventures. Build the perfect overlanding setup today and enjoy freedom without limits.
