TOPSECRETTUNDRA
Off that bat I know there is some good info already on here about this process. This is more for the members who are not quite the shade tree mechanic. I called the dealer to see what they wanted for the job and they quoted me $260 but like I have always said you don't take your car to a mechanic or dealer because it's a good deal.
I ordered the plugs through sparkplugs dot com and they came in a couple days. I think they were $25 with shipping. I decided to go with the OEM Densos. The whole process is very easy, a swivel socket makes a job a lot easier on the drivers side. I took me about 30 mins to do all six.
Here are the Densos I went with:
I started with the passenger side, unbuckle the two clips for the air intake and tuck the inlet pipe off to the side. No need to remove it any further.
With that out of the way you can see your coils. Use a small flat-head screwdriver to release the clips. Don't go full re**** on them, just gently pry to release the clip.
After that remove the 3 10mm bolts holding on each of the coils revealing your plugs.
When you put the new plugs in, screw them in by hand until they get tight. I did 4 quarter turns past that with the ratchet to make them snug.
Reverse order, bolt the coils back in, re-clip the plugs, then reconnect your air intake.
Now for the drivers side. It's a little more crowded on this side but still pretty easy. I removed a vaccum line from the red circle and tucked it away near the firewall.
Same process as the passenger side. Remove the clips with a small screwdriver to help pop the clip, remove the bolts for the coils, pull out the coils, remove old plugs, install new ones, reinstall coils, bolt in coils, replug coils, reattach vacuum line and thats it.
Here is a picture of the coils out of the truck:
Here is the drivers side all back together.
After it was all done I took it for a spin, 20 mile trip, averaged 40mph and turned this MPG which a little better than what I usually get.
If this helps one member save $235 from the dealer then it was worth the 15 minutes it took me to make this thread.
-Ryan
-Ryan
