Veritas
Hi Everyone,
I am getting ready to replace the WS-ATF transmission fluid in my 4runner and I was looking for some advice. I bought 14 quarts and I searched on here and the only thing I could find was to cycle the fluid and dump the pan each time or I could disconnect one of the hoses that the pump feeds into and drain it there(not sure which one though). Also I wanted to do a drain and fill, not necessarily a flush, I don't see any strong reason to go through that hassle.
I have never done a full system before and the reason that I am doing it now is because I drained part of the fluid pan and it was a brown/straw color and smelled sweet and burned. I bought the car used and it has 56,000 miles on it. I was disappointed when I saw the color and decided I would replace all the fluid myself to play it safe.
I know how to do this with the refill plug and the overflow plug on the transmission as well as using the computer to turn the A/T temp light on and off to check for its temperature. So I think I have all my bases covered, but it never hurts to talk to other people and learn what they have.(like doing a drain and fill versus a full flush)
Basically can anyone share their best way of doing it, any steps they have, or any knowledge they can share? I would greatly appreciate it!
Update to add:
After much research I decided it is best to go with a drain and fill rather than a full flush of the system. To each his own, but that was my decision.
Do it properly following this method:
http://www.tacomaworld.com/forum/2nd-gen-tacomas/68462-diy-full-flush-automatic-transmission.html
Update to add:
