Thai
Elite Member
LANDCRUISER 200 HAS INCREASED ACTIVE SAFETY
Toyota's new LandCruiser 200 has a comprehensive active safety package as standard equipment.
LandCruiser 200's active safety credentials begin with its new underpinnings, including torque-sensing full-time 4WD, a wider track, all-new coil-spring double-wishbone front suspension, Kinetic Dynamic Suspension System (KDSS)* and a new larger brake package.
In addition, LandCruiser 200 has a new brake control system, with All-Terrain ABS, Electronic Brakeforce Distribution (EBD) and Brake Assist (BA) as standard equipment.
The new LandCruiser also has an advanced package of Drive Assist Technology (DAT) features as standard equipment.
All LandCruiser 200 models have Vehicle Stability Control (VSC) and Active Traction Control as standard equipment.
LandCruiser's VSC now has the added feature of a VSC cut-off switch, which deactivates both the VSC and TRC to help the vehicle escape from mud, fresh snow or other slippery terrain.
The vehicle must be stationary before the VSC cut-off can be activated.
Active TRC provides high levels of grip in off-road driving, without the need to engage the centre differential lock.
All LandCruiser 200 models have Hill-start Assist Control to prevent the vehicle rolling downhill when taking off on a steep incline.
LandCruiser 200 petrol models have newly developed Toyota Crawl Control, to control vehicle speed in extreme 4WD conditions.
LandCruiser 200 diesel models have Downhill Assist Control (DAC) to maintain vehicle speed on steep off-road descents.
LandCruiser 200 VX and Sahara have the additional active safety feature of front foglamps.
Top-of-the-range Sahara has a reversing camera, audio controls on the steering wheel and a headlamp cleaning system.
LANDCRUISER 200 HAS INCREASED PASSIVE SAFETY
Toyota's new LandCruiser 200 has increased passive safety, with an all-new body and frame and up to 10 SRS airbags.
Pedestrian safety has also been significantly increased.
Toyota has paid particular attention to the crashworthiness of the frame and the interaction between the frame and upper body in absorbing collision impact.
LandCruiser 200 has an all-new frame and newly designed underbody reinforcement in the upper body.
They are designed to act as one unit to better absorb impact in a frontal collision, by bending the frame and axial compression of the underbody reinforcement.
The frame has been completely redesigned at the front, as a moment-reducing structure.
The front side rails have 30 per cent more horizontal offset and 40 per cent less vertical offset to increase impact absorption.
The frame's side rails have preset bending points between the number two and number three cross-members.
Impact energy support areas (large reinforced box sections) have been built into the side rails at the number three cross-member joint.
These box sections are pressed from high-tensile sheet steel and have reinforcements in all four corners and for the entire outboard plate.
The front frame structure has been designed to increase impact absorption while increasing ground clearance for the front differential and the power steering box.
Inside, the LandCruiser 200 has head impact-absorbing structures for the inner materials of the pillar garnishes and roof headlining.
Each pillar garnish has one-piece moulded ribs to act as energy-absorbing panels.
The roof headlining has energy-absorbing resin angle brackets.
Vehicles equipped with a rear cooler have an added energy-absorbing structure on the rear cooler duct.
